stunner5000pt
- 1,447
- 5
Hvae a look at the diagram
Caluclate the force on the point charge q, due to a uniformly charged rod of length L a distance x from the point charge q. Discuss the limit when L approaches infinity with lambda = Q/L fixed.
[tex]Q = \lambda L[/tex]
[tex]dQ = \lambda dL[/tex]
Force of dQ on the point charge q is given by
[tex]dF = \frac{1}{4 \pi \epsilon_{0}} \frac{qdQ}{(L+x-s)^2}[/tex]
no Y components since the rod is thin. SO this force is the total force in the horizontal direction only.
[tex]F = \int dF = \int_{s=0}^{s=L} \frac{1}{4 \pi \epsilon_{0}} \frac{q \lambda ds}{(L+x-s)^2}[/tex]
[tex]F = \frac{q \lambda L}{4 \pi \epsilon_{0}} \frac{1}{x(L+x)}[/tex]
[tex]F = \frac{Qq}{4 \pi \epsilon_{0} x(L+x)}[/tex]
now for the limit where L -> infinity
i used L'Hopital's Rule and got the answer to be zero. But i find it hard to believe that that is the case. I Would think that this has something to di wth the limtis of integration being s=0 to s=infinity
im not sure however... do help
thank you in advance for your help!
