Calculating Tangent for Accelerated Motion: Rise/Run?
  • Thread starter Thread starter Turvey
The proper formula to calculate the tangent on a graph representing accelerated motion (Position vs. Time) is indeed rise/run; however, this applies only to straight lines. For graphs depicting constant acceleration, the slope of the tangent line varies and is determined by taking the derivative at a specific point. When calculating the slope of a tangent line, any two points on that tangent line can be used, provided they are accurately drawn. This discussion clarifies the distinction between straight lines and curves in motion graphs.
  • Understanding of calculus, specifically derivatives
  • Familiarity with graphing concepts, particularly Position vs. Time graphs
  • Knowledge of the concept of slope in mathematics
  • Basic principles of accelerated motion in physics
  • Study the concept of derivatives in calculus
  • Learn how to graph Position vs. Time for objects in accelerated motion
  • Explore the relationship between slope and tangent lines in calculus
  • Investigate the principles of constant acceleration in physics
Students and educators in physics and mathematics, particularly those focusing on motion analysis and calculus applications. This discussion is beneficial for anyone looking to deepen their understanding of graphing techniques and the mathematical principles behind motion.
Turvey
Just making sure that the proper formula to calculate a tangent on a graph, (Position vs. Time) that shows an accelerated motion is rise/run.
And also, I would like to make sure that if it asks you to start at the point 0.15s, that as long as you draw the line to cross a point without going through the line, you can virtually pick any point on the x and y-axis to produce the correct answer, as long as the line touches the starting point on the x axis.
Thanks for reading, and any response is greatly appreciated.
This not at all clear. You talk about "graphs" but you seem to be thinking specifically about motion. If you have a "distance versus time" graph, with constant acceleration, then the graph is NOT a straight line, the slope of the tangent line at any point varies with the point, and the slope is not "rise over run" since neither is those is defined at a single point. The slope of the tangent line can be calculated by taking the derivative.
It is true that for a straight line, you can use whatever (x,y) points you want (on the line of course) to calculate the slope- that's true since the slope of a straight line IS a single number and is independent of the points you use to calculate (y1- y0)/(x1-x0). SO if you (accurately) draw the tangent line (that may be what you meant by "draw the line to cross a point without going through the line") then you can use any two points on that tangent line to find the slope of the tangent line.
(Though I might point out that the "tangent line" to y= x3 at x= 0 does "go through" the graph!)
  • · Replies 19 ·
  • · Replies 18 ·
