How Many Water Molecules Are in a 1.5 mm Raindrop?
  • Thread starter Thread starter mh922253
The discussion focuses on estimating the number of water molecules in a raindrop with a radius of 1.5 mm. To solve this, one must use the equation for the volume of a sphere, V = (4/3)πr³, and apply the density of water, which is 1 gram per cubic centimeter. The molecular mass of water is approximately 18 grams per mole, and Avogadro's number (6.02 x 10²³) is used to convert moles to molecules. This method provides a systematic approach to calculating the total number of water molecules in the specified volume.
  • Understanding of spherical volume calculation (V = (4/3)πr³)
  • Knowledge of water's density (1 gram per cubic centimeter)
  • Familiarity with molecular mass of water (18 grams per mole)
  • Awareness of Avogadro's number (6.02 x 10²³ molecules per mole)
  • Research the concept of molar volume and its application in chemistry.
  • Learn about the properties of water, including density and molecular structure.
  • Explore volumetric calculations in different geometric shapes.
  • Study the significance of Avogadro's number in chemical calculations.
Students studying physics or chemistry, educators teaching molecular calculations, and anyone interested in understanding the quantitative aspects of water in meteorological contexts.
mh922253
am i in the right place?
i everyone i have a physics question but i am not sure if i am in the right place or not... the question is:
Estimate the number of water molecules in a raindrop 1.5 mm in radius.
i really don't want you to solve it just give me the equation that i am supposed to use to solve the question...
and again... if i am in the wrong place...please tell me where i am supposed to post this question
thanks a lot
This is better posted in the homework forum.
Look up the molar volume of water. You'll find out how many atoms fit into a given volume. The rest is just volumetric calculation.
The density of water is 1 gram per cubic centimeter. The molecular mass of water is about 18 grams per mole. there are about 6.02*10^23 molecules in a mole. Assuming the raindrop is spherical, you can find its volume from [itex]V=\frac{4}{3}\pi r^3[/itex]. Using the desnity, you can find the mass, using the mass you can find the # of moles, using the # of moles you can find the # of molecules.
  • · Replies 43 ·
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 64 ·
