PrudensOptimus
- 641
Can someone distribute their knowledge of the above topics? I have a test on these tomorrow.
Thanks.
Thanks.
The discussion revolves around the concepts of work, energy, power, and momentum, including their definitions, relationships, and calculations. Participants explore theoretical aspects, mathematical formulations, and practical implications of these topics, as well as their applications in various scenarios.
Participants express varying interpretations of the relationships between work, energy, and momentum, with some points of contention regarding the application of the work-energy theorem and the treatment of conservative versus non-conservative forces. The discussion remains unresolved on several technical aspects.
There are limitations in the discussion regarding the assumptions made about forces and energy types, as well as the mathematical steps involved in integrating work. Some participants express uncertainty about specific calculations and conditions for applying certain equations.
I'm assuming that you mean you tried to use the integrate idea to find work. Don't forget that force is a vector, so it is a dot product of the force with the displacement. Also, one subtle issue, work is <i>usually</i> associated with a particular force (i.e. friction), not the resultant, so you usually will not have that summation in the integrand. I'm really sorry, but I don't quite follow what you are trying to do.Originally posted by PrudensOptimus
I tried to integrate Work, ∫ΣF dx, where x is displacement, replacing F with ma, I end up getting δKE∫1/dx dx.
You probably use this notion when you are considering the work being done by the potential energy in the problem. If you include the potential energy in the problem, then the system is conservative. If you define the system without the potential energy (i.e. call gravity an external force), then the system is not conservative.Originally posted by PrudensOptimus
When do you use Wnet = ΔKE?
I saw some questions where W = ΔKE + ΔPE.
Or was that just for non conservative works? If it is for non conservative works only, then that means in cases when W = ΔKE, the W must mean for conservative?
It looks like they are using the subscript, "NC," to indicate that they are strictly talking about "Non-Conservative" work. That means that there is no potential energy that you can associate with it. Friction, I'm pretty sure, will contribute to the WNC. Gravity, and spring force stuff, goes into the ΔPE on the right.Originally posted by PrudensOptimus
What does it mean:
"It must be emphasized that all the forces acting on a body must be included in equation 6-10 either in the potential energy term on the right (if it is a conservative force), or in the work term WNC, on the left(but not in both!)"
EQ 6-10 : WNC = ΔKE + Δ PE.
Is this what you were trying to do?
∫Fdx = ∫madx = m∫(dv/dt)dx = m∫(dv/dx)(dx/dt)dx
= m∫(dv/dx)vdx = m∫vdv = (m/2)[v2 - v02] = KE - KE0 = ΔKE
F is the integrand, and it can be a function of the position of the particle, in general. If you replace it by ma, then the a must be a function of the position of the particle, in general. You cannot replace this by a constant, in general.Originally posted by PrudensOptimus
When I replaced F with ma, and a with (v^2 - v0^2)/2Δx, isn't m((v^2 - v0^2)/2) suppose to be treated as constants?
This is the chain rule in action:Originally posted by PrudensOptimus
mç(dv/dx)vdx --- how did you get to that part?
