Find d for |f(x) - (1/5)| < .05 if |x-5| < d
  • Thread starter Thread starter Soaring Crane
    Proof
The discussion centers on finding the value of d such that |f(x) - (1/5)| < 0.05 when |x-5| < d, with the limit of the function f as x approaches 5 being 1/5. The correct value of d is determined to be 1.67 after evaluating two initial delta values, d_1 = 1 and d_2 = 1.67. The method involves ensuring that a single value of d satisfies both conditions of the limit and the epsilon constraint. The final conclusion is that d must be set to 1.67 to meet the criteria.
  • Understanding of limits in calculus
  • Familiarity with epsilon-delta definitions of limits
  • Basic algebra for solving equations
  • Knowledge of function behavior near specific points
  • Study the epsilon-delta definition of limits in more detail
  • Learn how to apply limits to different types of functions
  • Explore the concept of continuity and its relationship with limits
  • Practice solving limit problems using various functions and epsilon values
Students of calculus, mathematics educators, and anyone looking to deepen their understanding of limits and epsilon-delta proofs.
Soaring Crane
A positive number E and the limit L of a function f at a are given. Find a number d such that |f(x) - L| < E if 0 < |x-a| < d.
Lim x --> 5 (1/x) = 1/5; E = 0.05
The answer or value of d = 1/505.
These are the steps that I did, and, unfortunately, my efforts did not end in that result.
|f(x) - (1/5)| < .05 if |x-5| < d.
a. f(5 - d_1) = (1/5) + .05 = 0.25
1/(5 - d_1) = 0.25
d_1 = 1
b. f(5 + d_2) = (1/5) - 0.05 = .15
1/(5 + d_2) = 0.15
d_2 = 1.67
Neither delta fits the answer. Why is my proof terribly incorrect? Is there an alternate method?
Thanks.
Your proof is not incorrect, but you are using two different delta values. For |f(x) - L| < E to be true, 0 < |x-a| < d must be true for the same value of d. You need to set a single value for d that satisfies both of these conditions. To do this, start by setting d to the smaller of the two deltas (in this case, d = 1). Then, check that |f(5+d) - L| < E is also true. If it is not, then increase the value of d until it is. In this example, we have |f(5+1) - L| = |(1/6) - (1/5)| = 0.16, which is not less than 0.05, so we need to increase the value of d. We can do this by setting d = 1.67 (the larger of the two deltas you calculated), which gives us |f(5+1.67) - L| = |(1/6.67) - (1/5)| = 0.04, which is less than 0.05. Therefore, the answer is d = 1.67.
  • · Replies 25 ·
  • · Replies 0 ·
