Geometry Discrete Problem Thanks
The discussion focuses on solving a geometry problem involving an advertising sign supported by a horizontal steel brace and a wire at a 25-degree angle. The force of gravity acting on the sign is 850N. Participants are advised to draw a free body diagram to visualize the forces and resolve them using trigonometric principles. A common misconception addressed is that the compression force acts inward; instead, it acts outward from the building.
  • Understanding of free body diagrams
  • Basic knowledge of trigonometry
  • Familiarity with vector resolution
  • Concept of tension and compression forces
  • Study vector resolution techniques in physics
  • Learn about free body diagram construction
  • Explore trigonometric functions and their applications in force analysis
  • Investigate real-world applications of tension and compression in structural engineering
Students studying physics, engineering students, and anyone interested in understanding forces acting on structures.
Karma
An Advertising sign is supported by a horizontal steel brace extending at right angles from the side of a building, and by a wire attached to the building above the brace at an angel of 25. If the force of gravity on the sign is 850N, find the Tension in the wire and the compression in the steel brace
You should post your attempts at the problem as well, not just the question. But to get you started, draw a free body diagram around the end of the brace, where the steel, wire and advertising sign all meet, and resolve the forces.
You have the EXACT same textbook as me!
This question is actually really easy once you understand a couple key things. You must first draw a diagram, and remember your arrows on your vectors. Also, it is a common misconception that for these types of problems the compression force is inwards (so in this case toward the building). Actually, the force is outwards. Once you realize this you can simply set up your vectors forming a right angle triangle...use trig to solve.
Post the steps you have, I'm not going to give you the answer, so I'll check your work with mine (my math teacher confirmed mine is correct). Good luck.
  • · Replies 18 ·
