Thermal resistance, can i do this?
The discussion centers on calculating thermal resistance for a wall composed of three layers: fiberboard, concrete, and brick. The user successfully applies the formula for thermal resistance, R = d/k, where d is thickness and k is thermal conductivity, to find the total resistance by summing the individual resistances of each layer. The calculated total thermal conductivity for the wall is approximately 0.476127. The consensus confirms that combining thermal resistances in series is valid, validating the user's approach.
  • Understanding of thermal conductivity and resistance principles
  • Familiarity with the equation R = d/k
  • Basic knowledge of heat transfer concepts
  • Ability to perform calculations involving multiple layers of materials
  • Research the concept of thermal resistance in series and parallel configurations
  • Learn about heat transfer calculations in multi-layered walls
  • Explore the impact of material properties on thermal performance
  • Investigate software tools for thermal analysis in building design
Students in engineering or architecture, building designers, and professionals involved in thermal performance analysis of structures.
ShawnD
I have this problem from my book here
A house has a wall made of 3 layers: fiberboard, concrete, brick where the fiberboard is on the inside of the house, brick is on the outside and concrete is in between.
the fiberboard is 0.02m thick, the concrete is 0.15m thick, the brick is 0.07m thick.
The thermal conductivity for fiberboard is 0.059, the concrete is 1.3, the brick is 0.71
the inside temperature is 20C, the outside temp is -10C
I'm supposed to find the amount of energy to conduct through the wall in 1 hour.
Since I have too many layers, I couldn't do the method of finding out temperature between the layers unless I made a pile of equations then put them in a matrix (which I hate doing).
I got the idea that I should try to make 1 big value for the conductivity of the wall.
Thermal resistance is given by this equation:
R = d/k where d is thickness and k is conductivity constant
I combined the resistances by simply adding them together (can I do this??)
[sum]R = d/k + d/k + d/k
[sum]R = 0.02/0.059 + 0.15/1.3 + 0.07/0.71
[sum]R = 0.504067
Then I rearrange the formula
R = d/k
Rk = d
k = d/R
k = (0.02 + 0.15 + 0.07)/0.504067
k = 0.476127 for the entire wall
Now that I got a k value for the entire wall, I just fill in for
Q = kA[del]Tt/d
Can I do the stuff I did with the adding of resistances like that or did I just do a bunch of voodoo math that is totally wrong?
Try
http://personal.cityu.edu.hk/~bsapplec/newpage218.htm
It seems to answer some bits of your question. From what I've found, it looks like you can combine thermal resistances in series the way you've done it.
Jess
  • · Replies 16 ·
  • · Replies 23 ·
