Special Relativity and radioactive nucleus
The discussion revolves around a problem in special relativity involving a radioactive nucleus that emits an alpha particle while in motion. Participants explore the calculations necessary to determine the speed of the nucleus in the laboratory frame based on the velocities and angles of the emitted particle in different reference frames.
  • Homework-related
  • One participant presents a problem involving a radioactive nucleus moving and emitting an alpha particle, seeking guidance on how to calculate the nucleus's speed in the lab frame.
  • Another participant suggests using the Lorentz transformation equations for the x and y components of velocity to relate the emitted particle's motion in the nucleus's rest frame to the lab frame.
  • Further contributions emphasize the need to consider the components of velocity and how they transform between frames, with specific formulas provided for these transformations.
  • Participants discuss the correct notation and relationships between the velocities of the alpha particle in different frames, with some expressing confusion over the equations and their derivations.
  • There is acknowledgment of mistakes in understanding the problem, particularly regarding which velocity corresponds to the nucleus and which to the alpha particle.
  • One participant expresses gratitude for the assistance received and reflects on their learning process throughout the discussion.
Participants do not reach a consensus on the final calculations or the correct interpretation of the equations, with some expressing uncertainty and revising their understanding as the discussion progresses.
Some participants mention specific equations and transformations without fully deriving them, indicating potential gaps in understanding or assumptions that are not explicitly stated.
Pyrokenesis
I was wondering if I could get some guidance regarding the following question:
"A radioactive nucleus, moving in a straight line, decays and emits an alpha particle. In the rest frame of the nucleus, the emitted particle moves with a velocity 6c/7, at an angle of 60 degrees to the direction of motion of the nucleus. If a laboratory experimenter observes the particle to be emitted at an angle of 30 degrees to the original velocity of the nucleus, calculate the speed of the radioactive nucleus in the lab frame."
A nudge in the right direction would be brilliant.
Thanks much,
Pyro...
Think about:
x'= (x - ut)/√(1 - u2/c2)
y' = y
and of course the transformations for t and vx (this is assuming you don't already have the transformation for vy
Cheers,
I shall now make an attempt to solve it.
I'm still slightly baffled, any further help would be brilliant!
Cheers.
Think about the problem in terms of the components of velocity (and as you need only consider two dimensions they are vx, which you should already have the formula for, and vy which you may not have the formula for, but should be able to derive) of the emitted particle in the rest frame of the nucleus and the rest frame of the lab and how they are related.
Okay, if u(x) = 6c/7cos(theta) then I think I'm on the right track.
And u(y) = u(y)'.
Thanx.
I'm not sure exactly what you want your notaion to mean but I think you may of made a mistake as vy is not equal to vy'.
Yes I see that now I was just being slow of brain, however I have an answer now for v using just the values of u(x) and u(x)', and the transformation velocity equation for u(x). Is that the velocity of the S' frame and is it needed?
I'm trying to work out exactl;y what you've claculated, but get the answer you need to work out an equation relating uy to uy'
To make it easier for you (though you will probably still need to derive this, if it's not given):
uy' = uy√(1 - vx2/c2)/(1 + uxvx/c2)
In this case u is the velocity of the alpha particle in the rest frame of the lab, u' is the velocity of the alpha particle in the rest frame of the nucleus and v is the velocity of the nucleus in the rest frmae of the lab.
I have an equation:
u(y)' = u(y)/(gamma)(1 - u(x)v/c^2).
Is this the equation?
Yes the two equations are equivalent,
Sorry, didnt see your last reply. Our equations look similar (apart from a difference in sign, mine is probably wrong then) and obviously v is the speed of the nucleus which is the moving frame.
I've just realized, I misread your first post, I thought 6c/7 was the velocity of the nucleus not the alpha particle, anyway it shouldn't matter too much it just means that the answer that I worked out for myself is wrong.
Thanx for all your help. Should have seen it all along!
  • · Replies 20 ·
  • · Replies 57 ·
  • · Replies 25 ·
  • · Replies 83 ·
