Help Kinematics in 2d Question
  • Thread starter Thread starter Morokana
    2d Kinematics
The discussion centers on solving a kinematics problem involving the motion of water at Niagara Falls. The horizontal speed of the water is 1.23 m/s, and the goal is to determine the vertical distance where the velocity vector points downward at a 49.4-degree angle. The relationship between the vertical and horizontal components of velocity is established using the tangent function, leading to the equation tan(49.4) = Vy / 1.23. Subsequently, the vertical displacement is calculated using the kinematic equation (Vy)^2 = u^2 + 2gy, where the initial vertical velocity (u) is zero.
  • Understanding of basic kinematics principles
  • Familiarity with trigonometric functions, specifically tangent
  • Knowledge of the kinematic equation for vertical motion
  • Ability to manipulate algebraic equations
  • Study the derivation and application of the kinematic equations in projectile motion
  • Learn about the role of gravitational acceleration (g) in vertical motion calculations
  • Explore the relationship between angles and velocity components in physics
  • Practice solving similar kinematics problems involving angles and displacement
Students studying physics, educators teaching kinematics, and anyone interested in understanding the principles of motion in two dimensions.
Morokana
Help! Kinematics in 2d Question!
Suppose the water at the top of Niagara Falls has a horizontal speed of 1.23 m/s just before it cascades over the edge of the falls. At what vertical distance below the edge does the velocity vector of the water point downward at a 49.4 degrees angle below the horizontal?
The angle is given as 49.4degrees...
And you know that tan of an angle will be y/x, and you're given the x velocity component, 1.23m/s...
Now, you can form an equation...
tan 49.4 = Vy/1.23
Solve it for Vy... (Vy is that final vertical velocity)
Then, to find the vertical displacement, use the formula (Vy)^2 = u^2 + 2gy given Vy, g and u. (It's a waterfall... so vertical velocity is assumably initially 0m/s)
Solve it for y. :}
Oh..
Hey thanks for your help man ... BUT ... i got it wrong ..andi failed ..
  • · Replies 20 ·
9K
