I can't get the actionscript working
  • Thread starter Thread starter JamesU
The discussion revolves around issues with ActionScript in KoolMoviesm, specifically regarding the functionality of a button intended to navigate to the next frame in a movie. Participants explore the mechanics of pausing the movie and the correct implementation of ActionScript commands.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant describes an issue where a button intended to go to the next frame instead causes the movie to advance immediately.
  • Another participant suggests trying to pause the frame that contains the button to prevent it from advancing automatically.
  • A different participant mentions adding an action to stop the movie, but it did not work as expected, leading to the next frame being displayed anyway.
  • One participant advises to first learn how to pause the movie on the desired frame before proceeding, mentioning the availability of tutorials for KoolMoviesm and expressing uncertainty about its workings.
  • Finally, a participant indicates that they resolved their issue.
The discussion contains multiple viewpoints on how to address the issue, with no consensus reached on the best approach to pausing the movie or implementing the ActionScript correctly.
Limitations include a lack of clarity on how to effectively pause the movie and the specific functionality of KoolMoviesm, as well as unresolved details regarding the ActionScript commands used.
JamesU
I'm using KoolMoviesm and I can't get the actionscript working. I want a button that when pressed, goes to the next frame. instead, I have a frame with a button, and then it immediately goes to the next frame. is there anything wrong with my script
Code:
 on(release)
nextFrame();
Computer science news on Phys.org
Have you tried pausing the frame that has the button on it?
I added an action that was supposed to stop the movie, but it just went on to the next frame
Well, first figure out how to pause (stop) the move on the desired frame, and then it will be easier (1 step at a time) :smile: I am not sure how koolmoviesm works personally, but there should be tutorials for it somewhere. Also, do you not like flash? There are a ton of resources on how to use flash.
okay, I got it now.
  • · Replies 19 ·
  • · Replies 20 ·
