The discussion revolves around a specific Java programming error, namely the " ')' expected " error, which participants are trying to diagnose and fix. The focus is on understanding the potential causes of this error within the context of a code snippet provided by one participant.
- Technical explanation
- Debate/contested
- Homework-related
- One participant inquires about the meaning of the " ')' expected " error and questions their use of parentheses in a specific line of code.
- Another participant suggests that such errors may stem from earlier syntactic mistakes and highlights a potential issue with a space between `num` and `3` in the code.
- A participant shares the complete code to provide context for the error and reiterates the specific error message encountered.
- Some participants continue to emphasize the space issue as the likely cause of the error.
- A later reply humorously suggests a method to fix the space issue, indicating a light-hearted approach to the problem.
- One participant expresses gratitude and confirms that removing the space resolved the error.
Participants generally agree that the space between `num` and `3` is the cause of the error, with one participant confirming that fixing it resolved their issue. However, there is some initial uncertainty about the nature of the error and whether it could be due to other syntactic mistakes.
There may be additional syntactic issues in the provided code, such as the use of `Int.parseInt` instead of `Integer.parseInt`, but these are not addressed in the discussion.
Individuals learning Java programming, particularly those encountering syntax errors, may find this discussion helpful.
