Measuring unknown emf by potentiometer
In measuring unknown electromotive force (emf) using a potentiometer, the stable current source, or working battery, must have a voltage greater than the emf being measured. This requirement ensures that there exists a point along the potentiometer's resistance where the voltage drop can equal the unknown emf. For instance, in a physics exercise using a slide-wire potentiometer, a battery with an emf slightly greater than 2 volts was utilized, allowing for accurate measurement across the 1-meter length of the slide wire, which corresponds to a 1V drop per meter.
  • Understanding of potentiometers and their operation
  • Knowledge of electromotive force (emf) concepts
  • Familiarity with voltage drop calculations
  • Basic principles of electrical circuits
  • Research the principles of slide-wire potentiometers
  • Study the relationship between voltage, current, and resistance in circuits
  • Explore the concept of stable current sources in electrical measurements
  • Learn about the applications of potentiometers in measuring unknown voltages
Physics students, electrical engineering students, and educators involved in teaching circuit theory and measurement techniques will benefit from this discussion.
tin llenaresas
in measuring unknown emf by potentiometer, why must the stable current source(working battery) have a voltage greater than any voltage to be measured?
i can't understand why..
in our exercise in physics, we used a slide-wire potentiometer with the assumption that 1 meter of the slide-wire gives a voltage drop of 1V. so, the battery we used has an emf slightly greater than 2 volts.
is there a connection between the length of the slide wire used and the use of a battery with an emf greater than 2V?
i am currently doing our physics lab report and honestly, its part of the discussion. I am asking for help for i can't understand.
tanx to anybody who dares to reply.. :smile:
Because you are finding the point along a length of an electrical resistance where the voltage is equal (and opposite) to the voltage you are trying to measure. The potential difference goes from 0 to maximum along that resistance, maximum being the voltage across the entire length.
If the voltage across that entire length is not greater than the voltage you are trying to measure, there will be no point where it is equal to the measured voltage.
AM
tanx buddy.ü
  • · Replies 22 ·
13K
