How do I balance net ionic equations for ionic compound reactions?
The discussion revolves around balancing net ionic equations (NIE) for reactions involving ionic compounds. Participants explore specific examples, including lead nitrate with sodium chloride and sodium hydroxide with ammonium chloride, as well as the reaction of carbon dioxide with calcium hydroxide. The focus includes theoretical understanding, the nature of electrolytes, and the correct representation of chemical species in the equations.
  • One participant presents a net ionic equation for the reaction of lead nitrate and sodium chloride but struggles with balancing it, noting the difficulty in maintaining charge balance.
  • Another participant questions the charge of lead in the products, suggesting that lead chloride should be represented as PbCl2 instead of PbCl, indicating a misunderstanding of lead's oxidation states.
  • In the second reaction involving sodium hydroxide and ammonium chloride, participants discuss the electrolytic nature of NH4OH and whether it qualifies as a strong electrolyte, with some uncertainty expressed about NH4Cl's classification.
  • A participant introduces a new reaction involving carbon dioxide and calcium hydroxide, presenting a net ionic equation but receiving feedback about the oxidation states and the nature of the compounds involved.
  • Another participant suggests that carbon dioxide reacts with water to form carbonic acid, prompting a reconsideration of the reaction mechanism with calcium hydroxide.
  • Concerns are raised about the covalent nature of carbon compounds and their dissociation in reactions, emphasizing the need for clarity in representing the overall reaction.
Participants express differing views on the correct representation of chemical species and the nature of electrolytes. There is no consensus on the balancing of the equations or the classification of the compounds involved, indicating ongoing debate and uncertainty.
Participants highlight potential misunderstandings regarding oxidation states, the nature of ionic versus covalent compounds, and the dissociation of species in solution. These factors contribute to the complexity of balancing the net ionic equations presented.
amcavoy
I need to write the NIE for these:
1. "0.1M lead nitrate, [itex]Pb\left(NO_3\right)_2[/itex] and 1.0M sodium chloride, [itex]NaCl[/itex]."
2. "6M sodium hydroxide, [itex]NaOH[/itex], is added to 0.5M ammonium chloride, [itex]NH_4Cl[/itex]."
For the first one, I set up the following equation (not balanced):
[itex]Pb\left(NO_3\right)_2+NaCl\rightarrow PbCl+NaNO_3[/itex]
...however, I cannot seem to balance this. If I make it [itex]2NaNO_3[/itex], then I have to do the same to [itex]NaCl[/itex] on the other side, which in turn makes me have to do the same thing to [itex]Pb\left(NO_3\right)_2[/itex], and I keep going around in circles. Does anyone have a suggestion on this?
On the second problem, I set it up like this:
[itex]NaOH+NH_4Cl\rightarrow NaCl+NH_4OH[/itex]
Would I be correct to say that [itex]NH_4OH[/itex] isn't a strong electrolyte (because only NaOH, KOH, Ba(OH)2, and Ca(OH)2 are)? And as far as [itex]NH_4Cl[/itex] goes, I cannot tell if it is a strong electrolyte or not. For this molecule, how would I determine this?
Thanks a lot for your help.
Chemistry news on Phys.org
usually in a net ionic equation, there are ions (at least that's how I remember writting them out).
On the first equation,
lead starts out with a +2 charge, but then changes to a +1 on the product side. This is strange, since lead doesn't usually ever have a +1 charge, it likes +2 or +4. Not to mention, I think the propper formula for Lead Chloride is PbCl2, meaning that is does indeed carry the +2 charge all the way through the reaction. Are you sure it is suppose to be PbCl ?
In the second reaction, NaOH, NH4Cl, NaCl ad NH4OH are all very soluble and will break into ions in water.
I am not absolutely sure, but I don't think NH4OH is a string electrolyte, as it does not dissassociate nearly as much as other ionic compounds do, but I do know that NaOH and NaCl are strong electrolytes.
Thanks for the reply. I must have overlooked the charge. I figured those to out, but now on my last, I have this:
"Carbon dioxide is bubbled into an aqueous solution of 1.0M calcium hydroxide."
My equation is as follows:
[itex]CO_2+2Ca\left(OH\right)_2\rightarrow C\left(OH\right)_4+Ca_2O_2[/itex]
...after doing the work out, I come up with this net ionic equation:
[itex]C^{+4}+4OH^{-}\rightarrow C\left(OH\right)_4[/itex]
Did I do this correctly?
I am not sure if this helps, or is even steering you into the correct direction, but when you bubble CO2 into water, you usually get carbonic acid. Is it the carbonic acid or the CO2 that reacts with the calcium hydroxide? You might want to think about that, too.
No apm. Notice that the oxidation state of Ca in Ca2O2 is +1. This is not possible.
Also, if you write the equation with H2CO3 (as suggested by scrappychic) instead of CO2, it's easier to see that this is nothing but a neutralization reaction.
One thing that might help you in the future is to know that carbon usually does not form ionic compounds (examples are beyond the scope of what you are doing in this problem). The oxygen does not dissociate from carbon, because CO2 is covalent. Even though you may not have heard of carbonic acid, know that covalent compounds do not dissociate into ions, so you will have to find another method to get the overall reaction.
25K
11K
12K
24K
17K
