Calculating Integrals and Exponentials: Solving Tricky Equations
  • Thread starter Thread starter don23
The discussion revolves around calculating integrals and exponentials, specifically focusing on the expression involving \( e^t \) and \( e^{-t} \), as well as the integral of a vector function from 0 to \( \pi \). Participants are exploring the correct interpretation and evaluation of these mathematical expressions.
  • Mixed
  • Participants discuss the multiplication of exponential functions and question the interpretation of the integral involving trigonometric functions and vector components. There are varying interpretations of the integral's setup, leading to different proposed answers.
The discussion is active, with participants providing different perspectives on the integral's evaluation and questioning each other's interpretations. Some guidance has been offered regarding the evaluation process, but no consensus has been reached on the correct answer.
There is confusion regarding the notation used for the integral, particularly whether the variables \( i \), \( j \), and \( k \) are meant to represent vector components or scalar multipliers. Additionally, some participants note the importance of including the limits of integration in their evaluations.
don23
ok, first what is e^t times e^-t?
and can anyone help with this one:
the integral from 0 to pi of (sinti+costj+tk)?
is it -costi + sintj +(t^2/2)k?
thank you!
thank you!
Well e^-t x e^t is same as e^t-t so It should be e^0=1.
I haven't started on Integrals yet.
I believe
[tex]e^t e^{ - t} = e^0 = 1[/tex]
and
[tex]\int\limits_0^\pi {\left( {i\sin t + j\cos t + kt} \right)dt} = 2i + k\frac{{\pi ^2 }}{2}[/tex]
:smile: Just remember to take the limits of the integral.
You have antiderivative, now apply the algebra
[tex]\int\limits_0^\pi {\left( {i\sin t + j\cos t + kt} \right)dt} = 2i + k\frac{{\pi ^2 }}{2} + C[/tex]
bomba923, I think you've made a mistake here, :wink:
First, I think the question reads:
[tex]\int_0 ^ \pi (\sin (it) + \cos (jt) + kt) dt[/tex]
And second, where does the little 'C' come from? :smile:
Nope, it isn't.
In your post, you didn't state the variable of integration. So I assume it is dt.
So:
[tex]\int (\sin (it) + \cos (jt) + kt) dt = \int \sin (it) dt + \int \cos (jt) dt + \int kt dt[/tex]
[tex]= \int \frac{1}{i} \sin (it) d(it) + \int \frac{1}{j} \cos (jt) d(jt) + k \int t dt[/tex]
[tex]= \frac{1}{i} \int \sin (it) d(it) + \frac{1}{j} \int \cos (jt) d(jt) + k \int t dt = ...[/tex]
Can you go from here?
Viet Dao,
You have confused me here.
I thought the question asked:
[tex]\int_0 ^ \pi ((\sin t)i + (\cos t)j + (t)k) dt[/tex]
My answer is
[tex]i + j + \frac{{\pi ^2 }}{2}k[/tex]
If I am asking some question like that, I am going to put the i, and j in front of the cos and sin functions.
Something like this:
i sint + j cost + kt.
Buzzer said:
My answer is
And even if the question reads like this:
That is still not the correct answer. :wink:
EDIT:
If the question happens to be:
int (i sint + j cost + kt) dt
You can use bomba923's suggestion. You should omit the constant of integration 'C' in his answer.
Viet Dao,
Ok, but I learned to put i, j and k at the end when I did vectors...
I did it again and got the same answer. Where does 2i come from?
EDIT
How stupid of me, I had pi/2 in my head instead of pi.
Certainly anyone taking calculus should have learned long ago that axbx= ax+y. In particular, axa-x= a0= 1. The fact that a= e is irrelevant.
Yes, the original post's "integral from 0 to pi of (sinti+costj+tk)" should have been written
[tex]\int_0^{\pi}{(sin t)i+ (cos t)j+ (t)k} dt[/itex]<br /> to distinguish it form [tex]\int_0^{\pi}{sin ti+ cos tj+ tk} dt[/itex] but I think the "i, j, k" suggested vectors rather than numbers.<br /> <br /> don23, It is true that<br /> [tex]\int {(sin t)i+ (cos t)j+ (t)k}dt= -cos(t)i+ sin(t)j+ (\frac{1}{2}t^2+ C[/tex]<br /> but you forgot to evaluate it between 0 and [itex]\pi[/itex].<br /> <br /> [tex](-cos \pi)i+ (sin /pi)j+ \frac{1}{2}(/pi)^2= i+ 0j+ \frac{\pi^2}{2}k[/tex]<br /> and<br /> [tex](-cos 0)i+ (sin 0)i+ \frac{1}{2}(0)^2= -i+ 0j+ 0k[/tex] <br /> so<br /> [tex]\int_0^{\pi}{(sin t)i+ (cos t)j+ (t)k}dt= 2i +\frac{\pi^2}{2}k[/tex][/tex][/tex]
Thank you Halls of Ivy :redface:
(you've vindicated me!)
  • · Replies 19 ·
  • · Replies 19 ·
