Binomial Theorem Application in Cauchy's and Sellmeier's Equations
The discussion revolves around the application of the binomial theorem in the context of Cauchy's and Sellmeier's equations, which are used in optics to describe the refractive index of materials. The original poster is attempting to show how Cauchy's equation serves as an approximation of Sellmeier's equation under certain conditions.
  • The original poster seeks clarification on how to apply the binomial theorem to expand Sellmeier's equation, particularly in the context of taking the square root and rewriting terms. Some participants suggest specific methods for expansion and manipulation of the equations.
Participants are actively engaging with the problem, offering insights on how to approach the expansion using the binomial theorem. There is a productive exchange of ideas, with some guidance provided on rewriting terms for easier manipulation.
The discussion includes considerations of the conditions under which the approximation holds, specifically when the wavelength is much larger than certain critical values. There is also a hint provided in the original problem that participants are interpreting and debating.
Luminous Blob
I am trying to do a question from Eugene Hecht's Optics book, which goes something like this:
Given the following equations:
Cauchy's Equation:
[tex]n = C_1 + \frac{C_2}{\lambda^2} + \frac{C_3}{\lambda^4} + ...[/tex]
Sellmeier's Equation:
[tex]n^2 = 1 + \sum_{j} \frac{A_j\lambda^2}{\lambda^2-\lambda_0_j^2}[/tex]
where the [tex]A_j[/tex] terms are constants and each [tex]\lambda_0_j[/tex] is the vacuum wavelength associated with a natural frequency [tex]v_0_j[/tex], such that [tex]\lambda_0_jv_0_j = c[/tex].
Show that where [tex]\lambda >> \lambda_0_j[/tex], Cauchy's Equation is an approximation of Sellmeier's Equation.
Now it also gives a hint which is as follows:
Write the above expression with only the first term in the sum; expand it by the binomial theorem; take the square root of [tex]n^2[/tex] and expand again.
From the hint, I gather that it means to rewrite Sellmeier's Equation as:
[tex]n^2 = 1 + \frac{A\lambda^2}{\lambda^2 - \lambda_0^2}[/tex]
From there though, I have no idea how to apply the binomial theorem to expand it. I just don't see how anything in that equation has the form [tex](x+y)^n[/tex], except for where n = 1.
If anyone can explain to me how to apply the binomial theorem to the equation, or if I've misunderstood what the hint means, it would be much appreciated.
You can use the binomial theorem to expand [itex](1+x)^{1/2}[/itex] when x<<1.
So you mean first take the square root of both sides, then expand it using the binomial theorem , letting [tex]x = \frac{A\lambda^2}{\lambda^2 - \lambda_0^2}[/tex], rather than first applying the binomial theorem, then taking the square root of both sides and then expanding again like the hint suggests?
Rewrite [tex]\frac{A_j\lambda^2}{\lambda^2-\lambda_0_j^2}[/tex] as
[tex]\frac{A_j}{\lambda^2}\frac{1}{1-\frac{\lambda_0_j^2}{\lambda^2}}[/tex] and expand the second part as
[tex]\frac{1}{1-x^2} \approx 1 - x^2 + x^4 - x^6 \ldots[/tex] where [tex]x = \frac{\lambda}{\lambda_0_j}[/tex]
Aah, I didn't think to do that. Thanks, that was a great help.
  • · Replies 18 ·
  • · Replies 19 ·
12K
