Challenging math questions involving polynomial functions
The discussion revolves around challenging math questions involving polynomial functions, specifically focusing on divisibility, remainders, and factorization of polynomials. Participants are exploring various problems related to polynomial equations and their properties.
  • Mixed
  • Participants are attempting to understand the implications of polynomial divisibility and the conditions under which certain statements hold true. They are discussing the use of the division theorem and exploring the relationships between polynomial coefficients and their factors.
Some participants have provided hints and guidance on specific problems, while others are expressing confusion and seeking further clarification. There is an ongoing exploration of different interpretations and approaches to the problems presented.
Participants are working within the constraints of high school-level mathematics, with some expressing uncertainty about advanced concepts like the division theorem. There is a recognition of varying levels of familiarity with polynomial functions and their properties among the participants.
an_mui
Any help with the following is appreciated. Thank you!
2. If 2x^3 - 9x^2 + 13x + k is divisible by x - 2, then it is also divisible by x -1.
I don't understand why this statement is true
8. An unknown polynomial f(x) of degree 37 yields a remainder of 1 when divided by x - 1, a remainder of 3 when divided by x - 3, a remainder of 21 when divided by x - 5.
Find the remainder when f(x) is divided by (x-1)(x-3)(x-5)
9. If ax^3 + bx + c, with a not equal 0, c not equal 0, has a factor of the form x^2 + px + 1, show that a^2 - c^2 = ab
10. Given that the cubic equation x^3 - 3x^2 + ax + b = 0 has rational coefficients and has the root - 1 + sqrt(3)i, determine the values of a and b.
2. Hint:
If P(x) is divisible by x-2, what must then P(2) be?
What have you tried on any of these?
8.
f (1) = ...a + b + c = 1
f (3) = ...9a + 3b + c = 3
f (5) = ...25a + 5b + c = 21
I know degree of f(x) = 37, which means that there's more than just a, b and c. However, I have no idea how to do this kind of questions. Sorry i forgot to show the work that i did.
9.
ax^3 + bx + c = f(x)
x^2 + px + 1 --> factor is of degree 2 so in order to get ax^3, I would need ax.
hm... so the factored form would be ...
(x^2 + px + 1)(x - h) = 0
this is all i could come up with on my own
10.
x1 = - 1 + sqrt(3)i
x2 = - 1 - sqrt(3)i
x3 = x3
(x - x3)(x - (-1 + sqrt(3)i)(x - (-1 - sqrt(3)i) = 0
(x - x3)(x^2 + 2x + 4) = x^3 - 3x^2 + ax + b
8. I think the division theorem would be much more fruitful. (Modular arithmetic better, if you've done arithmetic modulo a polynomial before)
You want to write f(x) = q(x) (x-1)(x-3)(x-5) + r(x), and you don't care about the actual value of q(x), just that degree(r) < 3.
9. the factored form would be ... (x^2 + px + 1)(x - h) = 0
Why do you have "= 0"? You're not solving an equation, you're factoring a polynomial! You want f(x) = something, not 0 = something! (I won't say more yet, I'll give you a chance to figure it out)
10.
No. Weren't you saying you were trying to factor f(x)? If so, then why are you introducing an "=0"?
This one is correct, though, but why'd you stop there?
Hi I solved 10. Could I get more hints on 8 and 9 though... I am still having troubles with them.
Well if ax³ + bx + c has a factor of the form x² + px + 1, then you know there is some polynomial r(x) such that:
r(x)(x² + px + 1) = ax³ + bx + c
Now you should be able to say something about the degree of r, as well as the leading coefficient of r. Do you know what those facts are?
Well you know that you can write f(x) = q(x)[(x-1)(x-3)(x-5)] + r(x). This is simply a consequence of the division algorithm, and the division algorithm tells you something about the degree of r. Knowing the degree of r, you can write r as a polynomial with unknown coefficients. You know that dividing f(x) by (x-1) gives a remainder of 1, so you know that:
f(x)/(x-1) = q(x)(x-3)(x-5) + r(x)/(x-1) has a remainder of 1, which simply means that:
r(x)/(x-1) has a remainder of 1. Using division algorithm again, you can say:
r(x) = q(x)(x - 1) + 1, since you know 1 to be the remainder. Since you should already know the degree of r, you know the degree of q. In fact, you also know how to express the leading coefficient of q in terms of the leading coefficient of r. You can make two more similar equations:
r(x) = p(x)(x - 3) + 3
r(x) = t(x)(x - 5) + 21
There are a certain number of unknown coefficients in r, and a number of unknown coefficients in each of the p, q, and t. But given these equations, as well as the fact that:
ax² + bx + c = a'x² + b'x + c' for all x if and only if a = a', b = b' and c = c'
you should be able to come up with n equations with n unknowns, and solving for your unknowns will include solving for those unknown coefficients in r, and r is the remainder you're looking for.
sorry i just realized i made a big mistake -_-! This isn't college math, this is just grade 12 calculus math. I don't know what the division theorem is! I am so sorry!
