What is the Magnitude of the Acceleration in This Newton's Laws Problem?
The problem involves calculating the magnitude of acceleration for a mass subjected to three forces in the xy plane, with specific magnitudes and directions given in Newtons and degrees. The original poster attempts to determine the acceleration by analyzing the forces' components and applying Newton's laws.
  • Exploratory, Assumption checking
  • Participants discuss the calculation of force components and the subsequent determination of acceleration. Questions arise regarding the treatment of mass and force units, particularly the confusion between mass in kilograms and force in Newtons.
Some participants have provided guidance on the correct use of units and the relationship between mass and weight. The discussion reflects a mix of interpretations regarding the calculations and the necessary steps to arrive at the correct acceleration.
There is a noted confusion about the conversion of mass to force, with participants questioning the assumptions made about unit conversions in the context of the problem.
ednof690
Problem: Three forces in an xy plane act on 3.10 kg mass. 16.90 N directed at 46 deg, 7.20 N directed at 119 deg and 9.20 N directed at 218 deg . (all angles are measured from the positive x-axis, with positive angles in the counter-clockwise direction.) Calculate the magnitude of the acceleration.
F1=16.90 cos 46 x+ 16.90 sin 46 y
F2= 7.20 cos 119 x +7.20 sin 119 y
f3= 9.20 cos 218 x + 9.20 sin 218 y
I keep getting the answer .422 m/s^2, however i am told this is incorrect. I calculated the x and y components for the forces, then added them independently and then I divided each by the mass (after converting to Newtons) which should give me the acceleration. I then calculated the magnitude by using the pythag. theorem. is there a step i am missing or am i completely off?
This seems OK. What did you get for the total force?
What do you mean "after converting to Newtons"? The mass should be in kg, as given. Perhaps here is your error.
I have no idea why i converted to Newtons, once i calculated it using the mass in kg , I got the correct acceleration. In what situation would i have to convert kg to Newtons?
Since kg is a unit of mass, not force, you can't "convert" one to the other. Sometimes you may be asked to find the weight of a given mass, but that's gotten by [itex]w = mg[/itex].
  • · Replies 42 ·
