Finding the Voltage Drop Across a Capacitor in a Series Circuit
The discussion revolves around finding the voltage drop across a capacitor in a series circuit involving a resistor and a time-varying voltage source. The circuit parameters include a 10 kHz signal and a 0.25 microfarad capacitor.
  • Participants discuss the application of Kirchhoff's voltage law and the implications of a time-varying voltage source on the capacitor's voltage. There are attempts to apply equations related to capacitor voltage, and questions arise regarding the assumptions about the circuit setup.
Participants are exploring the implications of the circuit configuration and questioning the validity of their assumptions. Some guidance has been offered regarding the need to write down Kirchhoff's voltage law and solve the resulting differential equation, but there is no explicit consensus on the next steps.
There is a mention of needing initial conditions for the circuit, such as the initial capacitor voltage, which may not have been provided in the original question.
Pepsi24chevy
I got a question that reads: Supoose a 10khz signal with an amplitude of 1 volt is applied across a 1k(ohm) trdidyot snf s 0.25 microF capacitor which are connected in series. What is the voltage drop across the capacitor?
I tried to use the equation Vc(t) + Vco*cos(omega*t) in which i got 1*cos(2*pi*10000*0.0025) in which i got -.92104. I don't think this is right, but i am not sure.
Help me get this straight: You've got a single loop circuit with a voltage source, a resistance, and a capacitance, is that it?
If that's the case then you can write down Kirchhoff's voltage law for the loop. You'll have a first order differential equation which you can solve for the capacitor voltage.
so the answer would be 1 since i would do 1volt(1kohms/1kohms)=1v?
Think about what you've just said. You've got a capacitor with a resistance hooked up to a time-varying voltage source. How can you have a constant voltage across the capacitor in that case? (Answer: You can't.)
Am I correct in my assumption about the setup of this circuit?
yes i believe you are correct. I copy the question just like it is in my pre lab.
OK, in that case you need to do what I said earlier. Write down Kirchhoff's voltage law for the circuit and solve the resulting differential equation. You will also need to know some initial condition for the circuit (like the initial capacitor voltage).
