Toluene + Bromine Mix: Reaction Test Results
  • Thread starter Thread starter apchemstudent
The forum discussion centers on the reaction between toluene and bromine, specifically addressing the expectation of a negative result for aromatic compounds. It is confirmed that toluene can indeed react with bromine under certain conditions, particularly through a light-catalyzed pathway. The reaction primarily involves the methyl group of toluene rather than the aromatic ring itself. This clarification indicates that the initial assumption of a negative result for toluene was incorrect.
  • Understanding of aromatic compounds and their reactivity
  • Knowledge of organic reaction mechanisms, particularly electrophilic substitution
  • Familiarity with light-catalyzed reactions
  • Basic laboratory techniques for mixing and observing chemical reactions
  • Research the mechanisms of electrophilic aromatic substitution reactions
  • Study the effects of light as a catalyst in organic reactions
  • Explore the reactivity of alkyl groups in aromatic compounds
  • Learn about safety protocols and best practices for handling bromine in the lab
Chemistry students, organic chemists, and laboratory technicians interested in reaction mechanisms and the behavior of aromatic compounds in chemical reactions.
apchemstudent
I mixed toulene + bromine and dichloromethane together, to see if a reaction occurs(decolourizes). However, i read in my lab manual that this test should be negative for aromatics. So is toluene suppose to be negative as well? If so i think something went wrong with my experiment. Thanks.
Chemistry news on Phys.org
What they meant by aromatic was probably benzene, toulene will react with bromine under appropriate conditions, for instance through a light catalyzed pathway...however its the methyl group which will react, not the aromatic ring.
13K
  • · Replies 0 ·
12K
