Question about vaiance, population and sample
  • Context: Undergrad
  • Thread starter Thread starter robert Ihnot
    population
The discussion revolves around the concepts of variance, specifically the differences between population variance and sample variance, and the rationale behind using different divisors (n vs. n-1) in their calculations. Participants explore theoretical explanations, examples, and the implications of these distinctions in statistical practice.
  • Some participants question the rationale behind dividing by n or n-1 in variance calculations, seeking a deeper understanding of the distinction.
  • One participant presents an example using dice rolls to illustrate how variance changes with sample size, noting discrepancies between calculated variances and the expected population variance.
  • Another participant suggests that the "divide by n" estimator is biased while "divide by n-1" is unbiased, inviting discussion on intuitive explanations for this bias.
  • There is a debate about the validity of using small sample sizes to estimate population variance, with some arguing that such estimates are conditional and may not reflect expected values accurately.
  • Participants discuss the implications of running experiments multiple times to compare the averages of different variance estimators, highlighting the differences in outcomes based on the divisor used.
  • One participant references a statistic book to explain why the expected value of the sample variance is less than the population variance, providing a mathematical derivation.
Participants express differing views on the appropriateness of using n vs. n-1 for variance calculations, with some agreeing on the bias of the "1/n" estimator while others challenge the implications of small sample sizes. The discussion remains unresolved regarding the best approach to understanding and applying these concepts.
Some participants note that the explanation of why the sample variance is biased may be insufficient in elementary statistics texts, and there are unresolved mathematical steps in the derivations presented.
robert Ihnot
In the October edition of the magazine, Active Trader, a reader writing in Chat Room, "Deviating from deviation?" asks that in explaining last month the viaiance, why did you not in your example divide by two?
{(8-9)^2 + (9-9)^2 +(10-9)^2}/3 = .667.
The explanation given is nothing more than,'That's how it is done,' and completely ignores, adding, "We're not math majors," the difference between the sample diviation and the population deviation. (There is no explanation of where the above example come from, and probably it is nothing but an equation invented by the writers.)
Elementary statistic books do a very poor job of explaining WHY that difference occurs, saying such as "It eliminates bias," or even "It makes the theory work out better, and isn't worth going into."
Does anyone have a good explanation of why there is that distinction, and assuming it is a sample deviation, why is it better to divide by 2 than by 3?
In the estimators section of your statistics text, you should get, either as a problem or example, a simple calculation that shows the "divide by n" estimator of population variance for variance of samples is biased, while "divide by n-1" is unbiased. Are you looking for an intuitive answer ?
Well, I have made up several examples about dice, but when the number of trials falls, say three throws of the dice, this greatly changes the variance.
This is my example, the population is the six sides of a dice, mean is 3.5 on a throw, variance is 2.92. Now if we throw three times, and get a perfectly reasonable outcome: 2,3,4. The mean is 3, and dividing by 2 the variance is 1, where as dividing by 3 it would have been 2/3. In neither case are we near 2.94. Thanks, bob
No, not "on average." Your example is conditional on a given sample. That's not a good basis to verify the expected value of any variance estimator.
Run this experiment a million times, and look at the average value for the variance that you compute.
Hurkyl: Run this experiment a million times, and look at the average value for the variance that you compute.
If it is so run, there will not be much difference between dividing by 1,000,000 or 999,999.
Correct, both "1/n" and "1/(n-1)" are unbiased estimators.
You entirely misunderstand:
You described an experiment where you roll a die three times, and then compute two different estimates for the variance, one where you divide by 3, and one where you divide by 2.
Now, you perform that experiment a million times, and you get a million estimates where you divided by 3, and a million estimates where you divided by 2.
You can then find the average of the divide by 3 estimates, and the average of the divide by 2 estimates. One of them will be (very close to) the actual variance. One will not.
They cannot possibly both be unbiased, unless the variance is zero.
if s/n is, on average (where s is the calculation in the numerator), the variance v, and so is s/(n-1), then we have:
E = nv
E = (n-1)v
0 = v
:-p
Hurkyl, you are correct. My bad. What I meant was, although the "1/n" estimator is biased, it is consistent.
Well, I got an answer here in this statistic book, "Principals of Statistics," MG Bulmer, dover paperback, 1967, p130:
"It may seem surprising that the Expected value of the sample variance is slightly less than the population variance. The reason is that sum of the squared deviations of a set of observations from their mean is always less than the sum the squared deviations from the population mean."
Good work; now you can give advice to the needy in these forums. :smile:
If we look at [tex]F(x)=\sum_{i=1}^{i=n}(a_i-x)^2[/tex]
By taking the derivative and setting it equal to 0, we arrive at the minimal value of the function: [tex]nx=\sum_{i=1}^{i=n}a_i[/tex]
Thus letting x take on the value of the mean of the sample gives us the minimal value for the variance.
On page 129-130, Principles of Statistics, we have this problem gone into, though here a few additional details are presented. He writes:
[tex](S^2)= \sum(x_i-X)^2=\sum(x_i-\mu)^2-N(X-\mu)^2[/tex]
for the above S^2 is as defined, N is the number of samples, mu is the mean, X is the sample mean, each X_i represents a variable that takes on various sample values.
Now the point is to find the expectation, E. We have:
[tex]E(\sum(x_i-\mu)^2 = N\sigma^2[/tex], where sigma is the STD.
For the second term, E(x)=mu, and we have [tex]N*E(X-\mu)^2=N*(EX^2-(EX)^2)[/tex]
The later term after N is [tex]V(X)=\frac{V(NX)=\sum V(X_i)=N\sigma^2}{N^2}[/tex]
Thus returning to the original equation we have:
[tex]E(S^2)=N\sigma^2-\sigma^2=(N-1)\sigma^2.[/tex]
Author adds: "Because of this fact S^2 is often divided by N-1 instead of N in order to obtain an unbiased estimate..."
  • · Replies 18 ·
  • · Replies 18 ·
