Angular velocity (check it out n tell me what u guys think)
The discussion centers on the concept of angular velocity and its implications when a mass chips off from a rotating disc. Referencing Resnick and Halliday's 5th edition, particularly chapter 10, participants explore the conservation of angular momentum and the relationship between linear and angular velocities. The consensus is that when a mass 'm' detaches from a disc rotating with angular velocity 'w', the disc's angular velocity will change due to the alteration in its moment of inertia. Additionally, it is established that not all bodies with linear velocities possess angular velocity concerning a fixed point.
  • Understanding of angular momentum conservation principles
  • Familiarity with linear and angular velocity concepts
  • Knowledge of moment of inertia calculations
  • Basic grasp of rotational dynamics as outlined in Resnick and Halliday
  • Study the conservation of angular momentum in rotating systems
  • Learn about moment of inertia and its effects on angular velocity
  • Explore the relationship between linear and angular velocities in physics
  • Review problem-solving techniques for rotational dynamics problems in Resnick and Halliday
Physics students, educators, and anyone interested in understanding the principles of rotational dynamics and angular momentum conservation.
phy_bits
angular velocity...(check it out n tell me what u guys think)
hello ppl...
consider this problem...
u could refer 2 resnick n halliday 5th edition, the 3rd author is krane. chapter 10, problem no. 8.
there's a disc that's rotating about a horizontal axis with angular velocity 'w'. a small mass 'm' just chips off n flies vertically upwards as the disc is rotationg, what is the final angular velocity of the disc.
now when the chip flies off, it has a linear vel= r.w
is it correct to assume it also has an instantaneous angular velocity= w ?
also refer problem 2 in the same chapter, it says 2 particles (mass 'm' each) r moving in opp directions with speed 'v' along parallel lines sep. by a dist. 'd' find the total angular momentum of system abt any origin.
the second problem requires us to find angular momentum of particles which r moving in st lines. r v req. to make a hypothetical assumption n find the ans. or do the actually have angular velocity.
on similar lines. if we assume the mass 'm' that chips off to have an angular velocity then the result obtained is that the disc continues to rotate with the same angular velocity. does that mean everytime we remove a portion of mass frm the disc, it continues to rotate with same ang. vel. 'w'?
please just answer the question ...do all bodies moving with linear velocities have ang. vel w.r.t a fixed point?
waiting 4 an answer...
bye
For the first problem, you'll want to note that angular momentum is conserved. If the piece flew off, you have a little change in the moment of inertia, which will result in a change in angular velocity.
Try showing some effort on the problem, #2 is hard to decipher.
  • · Replies 17 ·
