Is the Universe Shaped Like a Dodecahedron?
  • Context: Graduate
  • Thread starter Thread starter Spin_Network
    Shape Universe
The discussion revolves around the shape of the universe, specifically the hypothesis that it may be shaped like a dodecahedron. Participants explore various papers and models related to cosmic topology, the implications of WMAP data, and the potential for conflicting interpretations of the evidence. The scope includes theoretical considerations, interpretations of observational data, and the implications for cosmological models.
  • Some participants reference a paper suggesting that the universe could be modeled as a dodecahedron, highlighting its conceptual implications and visual representations.
  • Others argue that WMAP evidence may rule out the dodecahedral model, citing specific findings that contradict this hypothesis.
  • A later reply notes that while some models predicting matched circles are ruled out, the dodecahedron model with a 36-degree twist remains viable according to certain interpretations.
  • Participants discuss the existence of conflicting conclusions drawn from WMAP data, with some asserting that the data supports a flat, infinite universe, while others propose that it could also be consistent with a finite universe like the dodecahedron model.
  • One participant raises concerns about the interpretation of low-l modes in the WMAP data, suggesting they may challenge the standard model and support the idea of a finite universe.
  • Another participant shares links to additional resources and articles that explore the topology of the universe, indicating ongoing research and consideration of alternative models.
  • Some participants express skepticism about the definitive ruling out of the dodecahedral model, suggesting that further investigation is warranted.
Participants do not reach a consensus; multiple competing views remain regarding the validity of the dodecahedral model and the interpretation of WMAP data. Some assert it has not been ruled out, while others maintain that evidence contradicts it.
Limitations in the discussion include unresolved mathematical interpretations, the dependence on specific definitions of cosmic topology, and the varying interpretations of observational data from WMAP.
Spin_Network
This recent paper is interesting:http://arxiv.org/abs/physics/0509171
It has some interesting images, and it offers some conceptual thinks.
Astronomy news on Phys.org
JesseM said:
On the other hand, this paper argues that the WMAP evidence rules out the dodecahedral model:
http://www.arxiv.org/abs/astro-ph/0307282
There is a :N.B. that our results do not rule out the recently proposed dodecahedron model of Luminet, Weeks, Riazuelo, Lehoucq & Uzan, which has a 36 degree twist between matched circles.
If one looks closely in the link you provided?
Ah, you're right. I found the link to that paper on http://www.mathaware.org/mam/05/shape.of.universe.html, which seemed to say that Luminet and Tegmark had opposing conclusions:
Astronomers have analyzed the WMAP data and they have obtained conflicting results. Jean-Pierre Luminet and his colleagues proposed that the data seemed to best fit a universe that was a spherical space formed by identifying opposite faces of a dodecahedron in a three-dimensional sphere [10]. You can build a dodecahedron, a polyhedron with 12 pentagonal faces, to see that the faces cannot be glued straight across without first using a twist. Other mathematicians and physicists, such as Max Tegmark and his colleagues, assert that the WMAP data in fact rules out a finite universe, and that measurements point to a flat Euclidean space which is infinite [11].
But I guess the person who wrote the page didn't notice that note, or that the N.B. was only added in a later draft.
I just looked over the actual paper though, and it says:
Our results also rule out other models that predict
back-to-back matched circles. However, they do not rule
out the recently proposed dodecahedron model of [35]:
although this model predicts six pairs of diametrically
opposed circles of radius about 35°, the circles have a 36°
twist relative to their twin images, thereby eluding our
search method. After the original version of this paper
had been submitted, a more thorough analysis by Cornish
and collaborators [36] confirmed our findings and
improved them to rule out this and other twisted backto-
back models as well.
A maximally ambitious six-parameter “everything
bagel” circle search, corresponding to the general case
of arbitrary topologies, is currently being carried out
by Spergel and collaborators, and will be presented in
a forthcoming paper [37]. This should provide decisive
evidence either for or against the small universe hypothesis.
If this circle search confirms our finding that small
universes cannot explain the anomalies, we will be forced
to either dismiss the anomalies as a statistical fluke or to
search for explanations elsewhere, such as modified in-
flation models [21–26]. Even the fluke hypothesis might
ultimately be testable, since it may be possible to improve
the signal-to-noise of the large scale power spectrum
beyond the WMAP cosmic variance limit by employing
cluster polarization [38, 39] or weak gravitational
lensing [40] techniques.
There is a problem, not generally acknowledged, with the standard model interpretation of the WMAP/BALLOON/COBE data, that of the deficit of the low-l modes. While the standard model can explain this deficit as a statistical "fluke" as there are so few of these modes, the correlation between their positions and local geometry has led to their alignment being called "the axis of evil".
If this "AOE" is explained by local contamination of the data, or by a lensing of the cosmological dipole, then the deficit is made even worse.
Therefore these low-l modes (large angle anisotropies) may indeed be not consistent with the standard LCDM model prediction of a flat or open and therefore infinite universe but rather with a finite universe. Yet the data of l ~50 peak appears also consistent with a flat universe, so how can this be reconciled? By a model in which the universe is flat yet finite, such as the dodecahedron model, or by a conformally flat model.
Is this the reason WMAP2 is so long in being published?
Garth
In case it might be helpful in this thread, here is Niel Cornish homepage
http://www.physics.montana.edu/faculty/cornish/
and a sample article
http://arxiv.org/abs/astro-ph/0310233
"Constraining the topology of the universe"
I think he has considered the possibility that the U might have an unexpected topology, but (apologies) I'm a bit vague about this.
I agree with Spin. The dodecahedral model has not been ruled out. I was pretty sold on the Cornish explanation until recently. The paper Spin referenced is worth a look. So is this:
W Aurich et al. 2005 CMB anisotropy of the Poincaré dodecahedron
arXiv.org/abs/astro-ph/0412569
