What Volume of 0.0512 M Ca(OH)2 is Needed to React with 0.2 g of HNO2?
  • Thread starter Thread starter hebrewhammer640
    Volume
The discussion revolves around calculating the volume of 0.0512 M Ca(OH)2 required to react with 0.2 g of HNO2, based on the provided chemical equation. The scope includes stoichiometry and mole concepts in chemistry.
  • Homework-related
  • One participant presents the chemical equation HNO2 + Ca(OH)2 = H2O + Ca(NO2)2 and requests help in determining the required volume of Ca(OH)2.
  • Another participant asks for clarification on what the original poster has attempted so far and their understanding of the problem-solving approach.
  • A participant points out a potential error in the chemical equation, suggesting that the correct form should be 2 HNO2 + Ca(OH)2 → 2 H2O + Ca(NO2)2, indicating that two moles of HNO2 are needed.
  • There is a discussion about the importance of understanding the mole concept and stoichiometry, with one participant suggesting that the original poster should study relevant chapters in their chemistry text.
  • A later reply reiterates the need to convert grams of HNO2 to moles and find the corresponding moles of Ca(OH)2 needed, providing a step-by-step outline of the calculations involved.
  • Another participant mentions that the answer should reflect significant figures based on the initial mass of HNO2 provided.
Participants do not reach a consensus on the correct chemical equation or the approach to solving the problem. Multiple viewpoints and suggestions are presented, indicating that the discussion remains unresolved.
There are unresolved assumptions regarding the correct stoichiometry of the reaction and the interpretation of the chemical equation. The discussion also reflects varying levels of understanding among participants.
hebrewhammer640
Tough Problem
I need help with this problem. Using the chemical equation
HNO_2 + Ca(OH)2 = H20 + Ca(NO_2)2, What volume of .0512 M Ca(OH)2 is required to react with 0.2 g of HNO_2? Could you please also show me how to get the answer.
Chemistry news on Phys.org
Please first show us what you've tried so far.
What do you know about attacking problems like this ? What have you been taught and/or what does your text have to say about it ?
i don't really know much at all that's why I need help
First of all, one needs to write a correct equation, Ca(NO_2)2 has 2 (NO_2), so the left side require 2 HNO_2. BTW, is that HNO_2 (nitrous) or HNO_3 (nitric) acid?
With this equation, one using moles. When converting mass (g) to moles, one uses the atomic or molecular mass, e.g. 1 mole of H2 = 2 grams, and 1 mole of H2O = 18 grams.
A mole (abbreviated mol) of a pure substance is a mass of the material in grams that is numerically equal to the molecular mass in atomic mass units (amu). A mole of any material will contain Avogadro's number of molecules. For example, carbon has an atomic mass of exactly 12.0 atomic mass units -- a mole of carbon is therefore 12 grams.
from hyperphsics concepts - http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
For some examples of chemical equations, see - http://hyperphysics.phy-astr.gsu.edu/hbase/chemical/reactcon.html#c1
Well, you really need to learn at least an entire chapter then. Doing one problem for you will not get you terribly far. I suggest you study the chapter(s) in your chemistry text that deals with the mole concept and stoichiometry.
Really, that's the ONLY way to learn the subject...besides paying attention to what happens in classes.
Gokul43201 is correct (I do believe that reading books in general is one of the best way to learn-->or just in my opinion, textbooks can indeed teach better than teachers at times :rolleyes:)
As Astronuc suggested, I think your equation should be:
[tex]{\text{2HNO}}_{\text{2}} + {\text{Ca}}\left( {{\text{OH}}} \right)_2 \to 2{\text{H}}_{\text{2}} {\text{O}} + {\text{Ca}}\left( {{\text{NO}}_{\text{2}} } \right)_2[/tex]
If reaction goes to completion, then to find the volume of [itex]0.0512M\;{\text{Ca}}\left( {{\text{OH}}} \right)_2[/itex] needed to completely react with [itex]0.2g\; {\text{HNO}}_{\text{2}}[/itex], you might want to:
>>1) Convert [itex]0.2g\; {\text{HNO}}_{\text{2}}[/itex] to moles of [itex]{\text{HNO}}_{\text{2}}[/itex].
>>2) Find out from the balanced equation how many moles of [itex]{\text{Ca}}\left( {{\text{OH}}} \right)_2[/itex] you will need to react with the [itex]{\text{HNO}}_{\text{2}}[/itex].
>>3) Find out how many liters of [itex]0.0512M\;{\text{Ca}}\left( {{\text{OH}}} \right)_2[/itex] are needed to comprise that many moles of [itex]{\text{Ca}}\left( {{\text{OH}}} \right)_2[/itex].
>>Put it all together, and you'll have:
[tex]\left( {\frac{{0.2g\,{\text{HNO}}_{\text{2}} }}{{\text{1}}}} \right)\left( {\frac{{1{\text{ mol HNO}}_{\text{2}} }}{{47g\;{\text{HNO}}_{\text{2}} }}} \right)\left( {\frac{{{\text{1 mol Ca}}\left( {{\text{OH}}} \right)_2 }}{{{\text{2 mol HNO}}_{\text{2}} }}} \right)\left( {\frac{{{\text{1}}\,{\text{L}}\;{\text{Ca}}\left( {{\text{OH}}} \right)_2 }}{{0.0512{\text{ mol}}\;{\text{Ca}}\left( {{\text{OH}}} \right)_2 }}} \right) = \boxed{0.04\,{\text{L}}\;{\text{of }}0.0512M\;{\text{Ca}}\left( {{\text{OH}}} \right)_2 }[/tex]
And your answer will have one significant figure ---> due to those [itex]0.2g\;{\text{HNO}}_{\text{2}}[/itex] :wink:
Hope this helps! :smile: :shy:
(shouldn't this be in the homework section tho? :redface:)
  • · Replies 19 ·
11K
10K
