Register to reply
How long is the flea in the air for?
by quicknote
Tags: flea
Share this thread:
quicknote
#1
Sep23-05, 09:00 AM
P: 33
I'm having problems with this question. I know it should be simple, but I can't seem to get the right answer.
In this problem, you will use kinematic equations applied to a flea in free fall. Take the magnitude of free-fall acceleration to be g = 9.80 m/s^2.
If a flea can jump straight up to a height of 0.550 m, what is its initial speed v_0 as it leaves the ground?
My answer was 3.28 m/s, which is correct.
How long is the flea in the air?
I don't know which equations to use.
to reach it's max height, I used: t=d/v and got 0.168s
to reach the ground, I used: y1 = -0.5gt^2 and got 0.335s
so the total time I calculate was 0.503s
Can somebody help me?
Thanks
Phys.Org News Partner Science news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
Why plants in the office make us more productive
Tesla Motors dealing as states play factory poker
NateTG
#2
Sep23-05, 09:19 AM
Sci Advisor
HW Helper
P: 2,537
Quote Quote by quicknote
[itex]d=r \times t[/itex] only works for things that are moving at a constant speed.
There are a couple of ways to go about this:
For example, you could try using
[tex]0=v_0t-\frac{1}{2}gt^2[/tex]
for the entire jump.
P.S. Do you think it's odd that the flea took longer to fall than to rise?
Galileo
#3
Sep23-05, 09:21 AM
Sci Advisor
HW Helper
Galileo's Avatar
P: 2,002
Thanks
t=d/v holds only for constant velocity. From the moment the flea leaves the earth there is only one force acting on it, which is gravitational. So the flea accelerates with g the whole time.
You did use the right equation when it was falling down: y=-1/2gt^2.
If you use symmetry, you know the flea takes as much time going up as it does falling down.
HallsofIvy
#4
Sep23-05, 09:22 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,564
How did you get 3.28 m/s as the initial speed? I would assume you had to find the time until the greatest height in order to get that- if so, because of the symmetry, you only have to double that to find the total time in the air.
Or you could use h(t)= vt- 4.9t2= 0 when the flea is back on the ground, using the value you got for v, and solve for t.
Your "t=d/v and got 0.168s" is wrong because that only works for constant velocity.
Since the velocity at the top of the jump is 0, "y1 = -0.5gt^2 " does work for the time back to floor. It should be clear that, ignoring air resistance (which for a flea is not very realistic) the time from the floor to the top of the jump is exactly the same as the time from the top of the jump back to the floor.
quicknote
#5
Sep23-05, 10:10 AM
P: 33
Thank you all very much for the help...and quick replys!
I am glad that I found this board.
I used the equation: v1^2 = vo^2 - 2g(delta_y)
Register to reply
Related Discussions
The Flea Introductory Physics Homework 3
Flea zappers? General Discussion 9
How far can flea jump? Introductory Physics Homework 2
Flea problem Calculus & Beyond Homework 1
