How Do You Calculate the Electrostatic Force Between Two Charged Lines?
The discussion revolves around calculating the electrostatic force between two charged lines, specifically an infinite line of charge with a constant charge density and another line carrying uniform charges. The original poster expresses uncertainty about how to begin the problem.
  • Participants suggest starting with a diagram and establishing a coordinate system. There are discussions about the application of Gauss's law and the nature of the electric field generated by the charged lines. Questions arise regarding the limits of integration and the specifics of the charge distribution along the lines.
Guidance has been offered regarding the setup of the problem, including the importance of integrating only where charges are present and the need to label components in the diagram. Multiple interpretations of the integration limits and the direction of the electric field are being explored, indicating an ongoing discussion without explicit consensus.
Participants are navigating the complexities of the problem setup, including assumptions about charge densities and the geometric considerations of the lines involved. There is a focus on the mathematical representation of forces and fields, with some constraints implied by the nature of the homework task.
mousesgr
Electricity and Magnetism urgent!pls!
An infinite long line of charge of constant charge density a is located near the line AB which carries uniform charges with charge density b. Suppose both two lines are in the same plane, calculate the electrostatic force exerted on the line AB.
i don't know how to start...
Always start with a diagram, with labels
and a coordinate system. Label the items
described in the problems' situation,
and the quantity being asked about.
F=qE becomes F_vec = integral (dq E_vec).
Gauss says the infinitely-long charge density
carries a radial E-field that drops off as 1/r,
so unless AB is parallel to it, E=E(r).
If this sounds like gobbledy-gook, drop.
If this sounds like simple stuff you already knew,
the don't say "I don't know how to start".
the diagram
what is the limit of the integal then?
a to b or 0 to b?
you only need to integrate where the charges are ...
Your Diagram should include a dx (label it!)
and an E-field (presuming lamda_1 >0) at dx
F_on_dq = (dq)(E_at_dq)
If you integrate from 0 to A, use dq =0 there!
between A and B , dq = "b"dx .
what is the direction of dx & e-field then?
Come on! E-field due to the infinite line of charge
points _away_ from the positive charges there.
dx or dr is the coordinate (NOT vector) along line AB,
which is a geometric way of keeping track of the charges.
You're just adding F_vectors for each charge on AB ...
the total amount of charge on line AB is :
integral(dq) = integral(lamda_2 * dx) = lamda_2 * Length.
But don't expect F_total to be E(a+b/2) * lamda_2 * L !
  • · Replies 31 ·
