I don't understand the rank of a matrix
  • Thread starter Thread starter mr_coffee
    Matrix rank
The discussion revolves around understanding the concept of the rank of a matrix, specifically how to determine it from given examples. The subject area is linear algebra, focusing on matrix properties and linear independence.
  • Conceptual clarification, Mathematical reasoning
  • The original poster attempts to understand the rank of several matrices and expresses confusion regarding the results. Some participants provide definitions and methods for calculating rank, including Gaussian elimination and counting non-zero rows or columns.
mr_coffee
Hello everyone, can someone explain to me what the rank of a matrix is?
I have the following:
2 3 -2
2 6 0
-4 0 0
Rank = 3;
0 2 0 0
0 0 0 -4
0 0 0 0
9 0 0 0
rank = 3;
1 2
6 -3
Rank = 2;
I don't get it! any help would be great!
Hey,
The rank of a matrix is the number of linearly independent rows in the matrix.
You can find the rank by performing Gaussian elimination. The rank will then be the number of non-zero rows in the resulting matrix.
To compute the rank of a matrix, do the following.
1) Let [tex]A[/tex] be a [tex]m\times n[/tex] matrix.
2) Perform gaussian-elimination on [tex]A[/tex]
3) Count the number of non zero columns. This number is the rank of the matrix.
We'll start with your first example.
1) [tex]A = \left[ \begin{array}{ccc}2 & 3 & -2 \\2 & 6 & 0 \\-4 & 0 & 0 \\\end{array}\right][/tex]
2) Perform the gaussian-elimination on [tex]A[/tex]
[tex]A' = \left[ \begin{array}{ccc}1 & 0 & 0 \\0 & 1 & 0 \\0 & 0 & 1 \\\end{array}\right][/tex]
3) Now we count the number of non-zero columns:
[tex]A' = \left[ \begin{array}{ccc}(1) & 0 & 0 \\0 & (1) & 0 \\0 & 0 & (1) \\\end{array}\right][/tex]
Rank = 3
Now, what does the rank mean? Well the rank of a matrix let's you know the number of columns that cannot be written as a linear combination of each other.
If you consider [tex]A'[/tex] to be a matrix of vectors, we would have the following column vectors.
[tex]\vec{V_1} = (1,0,0)[/tex]
[tex]\vec{V_2} = (0,1,0)[/tex]
[tex]\vec{V_3} = (0,0,1)[/tex]
These vectors are ALL linearly independent of each other. Which means that the column vectors in [tex]A[/tex] are all linearly independent of each other.
Just don't forget that the rank only tells you the number of independent columns. If you are trying to find the spanning set, you must go back to the ORIGINAL matrix.
Awesome! thanks a lot guys! good explanation! :biggrin:
  • · Replies 31 ·
  • · Replies 20 ·
