DIFFEQ - Method of Undetermined Coefficients
The discussion revolves around the method of undetermined coefficients in solving a differential equation of the form 2y'' + 3y' + y = t^2 + 3*sin(t). Participants are exploring the process of finding a particular solution (y_p) and clarifying their understanding of how to equate coefficients from both sides of the equation.
  • Participants discuss splitting the particular solution into two parts, y_{p1} and y_{p2}, and setting up equations based on the coefficients of like terms. There are questions about how to derive the coefficients and the meaning of equating coefficients.
Some participants have offered guidance on how to equate coefficients and set up systems of equations, while others express confusion about the process and seek further clarification. There is an ongoing exploration of the steps involved in applying the method of undetermined coefficients.
Participants mention a lack of understanding regarding the derivation of specific coefficients and the assumptions underlying the method. There is also a reference to the challenge of applying these concepts to different problems.
FrogPad
Sup' all?
Ok, I have a quick question (hopefully). I'm trying to use the method of undetermined coefficients, and I keep getting stuck at one specific spot in the method. I'm not exactly sure what I'm doing. Let me try and explain:
The problem is given as:
[tex]2y''+3y'+y=t^2+3*\sin t[/tex]
Which leads to:
[tex]y=y_p+y_c|y_c=c_1 e^{\frac{-t}{2}} + c_2 e^{-t}[/tex]
Now, I'm sure that the [tex]y_c[/tex] portion is correct. It is the [tex]y_p[/tex] part that I get confused on.
I'll go through my steps, so you can see what I am doing right/wrong.
So, we first split [tex]y_p[/tex] as follows:
[tex]y_p=y_{p1}+y_{p2}[/tex]
Where:
(*1) - [tex]y_{p1}[/tex] satisfies [tex]2y_{p1}''+3y_{p1}'+y_{p1}=t^2[/tex]
(*2) - [tex]y_{p2}[/tex] satisfies [tex]2y_{p2}''+3y_{p2}'+y_{p2}=3\sin t[/tex]
For the [tex]y_{p1}[/tex] portion:
[tex]y_{p1} = At^2+Bt+C[/tex]
[tex]y_{p1}'' = 2At+B[/tex]
[tex]y_{p1}'' = 2A[/tex]
Plugging into (*1) yields:
[tex]2[2A]+3[2At+B]+[At^2+Bt+C] = t^2[/tex]
[tex][A]t^2 + [6A+B]t^1 +[4A+3B+C]t^0 = t^2[/tex]
Now this is where I get confused.
I'm supposed to factor and arrange the terms, and setup a system of equations?
So, maybe something like this?
[tex]t^2: A = \lambda_1[/tex]
[tex]t^1: 6A + B = \lambda_2[/tex]
[tex]t^0: 4A+3B+C= \lambda_3[/tex]
Now, how do I know what [tex]\lambda_n[/tex] are? The book, seems to magically find a number for them, but I'm NOT sure where those numbers are coming from. So if someone could explain this step, I would be very thankful. I think once I understand this step that I will be able to carry on with the other problems and do the [tex]y_{p2}[/tex] portion of this problem also.
Thanks in advance :)
Where:
Do it this way:
So you're left with:
[tex]2(2A)+3(2At+B)+At^2+Bt+C=t^2[/tex]
expand it out:
[tex]4A+6At+3B+At^2+Bt+C=t^2[/tex]
Now combine like factors:
[tex](4A+3B+C)+(6A+B)t+At^2=t^2[/tex]
Now equate the coefficients on both side for like terms:
A=1
6A+B=0
4A+3B+C=0
So solve for A, B, and C and do the same for the other one.
I don't understand what "equate the coefficients on both sides for like terms" means. I'm probably missing something really basic here. But, how are you getting the {1,0,0} in the system of equations?
FrogPad said:
Sup' all?
Which leads to:
Where:
The lambda are the coefficents. Equate them to the given coeffficients and solve for the unknowns using algebra.
No offense lurflurf, but I just said that I don't understand what "equate the coefficients means. So telling me to equate the coefficients again doesn't make any sense to me.
I'm just guessing here, but maybe it means this ?
Ok, so our factored equation with the appropriate [tex]y_{pn}^{(m)}[/tex] plugged in is:
So equating the coefficients means:
[tex]t^n : P(N) = \lambda_n[/tex]
Where [tex]\lambda_n[/tex] means the count of coefficients in the expression we are trying to find a function for.
So the function we are trying to find a [tex]y_{pn}[/tex] function for is [tex]t^2[/tex], which can be written as:
[tex]c_1t^2 + c_2t^1 + c_3t^0 |c_1=1,\,c_2=0,\,c_3=0[/tex]
So that is how you get the [tex]\lambda_n[/tex] expressions. So, equating the coefficients really does make sense after all.
Sorry lurflurf!
hehe, how could I have been so stupid :)
that's it? Right? grr... I hope that's what it is, I'll have to try it in a second with a different problem.
I'm probably too late but for the record here goes: So we have:
That's the same thing as :
[tex](4A+3B+C)t^0+(6A+B)t+At^2=0t^0+0t+1t^2[/tex]
Now, for this to be an equality for EVERY value of t, the coefficients on each power of t must be the same. So look at the coefficient on [itex]t^0[/itex]
That means:
4A+3B+C=0
right?
Same dif for t ok?
6A+B=0
Same for t^2:
A=1.
What about:
[tex](2a-4b+6a-12)+(22a-c)x+(-c+3d)x^2-(16c-22d)x^3=1-2x^2-x^3[/tex]
Can you set up the the four equations which "equate" coefficients? (Don't solve them as this is just a made-up problem ok)
[tex]2a-4b+6a-12 = 1[/tex]
[tex]22a-c = 0[/tex]
[tex]-c+3d = -2[/tex]
[tex]16c-22d = -1[/tex]
Thanks saltydog, I'm pretty sure I understand it. I seriously appreciate the help. I just didn't understand how the book was "magically" getting those numbers in the system of equations. So, thanks guys.
