[DiffEq] First order Modeling Applications
The discussion focuses on a modeling problem involving two sailboats, A and B, each with a mass of 60 kg and an initial velocity of 2 m/s. Both boats experience a constant wind force of 650 N, but differ in their water resistance characteristics. Boat A has proportionality constants of 80 N·s/m before planing and 60 N·s/m after, while Boat B has 100 N·s/m before planing and 50 N·s/m after. The solution requires solving the equations of motion using the formula F = ma + bv, integrating the results to determine which boat leads after a 500 m race.
  • Understanding of Newton's second law of motion (F = ma).
  • Familiarity with differential equations and integration techniques.
  • Knowledge of forces and motion in fluid dynamics.
  • Experience with piecewise functions, particularly the Heaviside function.
  • Study the application of Newton's laws in dynamic systems.
  • Learn about solving differential equations in motion problems.
  • Explore the Heaviside function and its applications in piecewise functions.
  • Investigate the effects of drag and resistance in fluid dynamics.
Students and professionals in physics, engineering, and applied mathematics, particularly those interested in modeling dynamic systems and analyzing motion under varying forces.
metiscus
YATP - Yet Another Trainlike Problem
Sailboats A and B each have mass 60kg and cross the starting line at the same time of a race. Each has an initial velocity of 2m/s.
Obviously from this, m1 = m2 == 60kg and vo1 = v02 == 2 m/s.
The wind applies a constant force of 650N to each boat and the water resistance is proportional to the velocity of the boat.
Boat A:
proportionality constants are b1 = 80 Nsec/meter before planing when the velocity is less than 5m/s and b2=60Nsec/m when velocity is aboce 5m/s.
Boat b:
proportionality constants are b1 = 100 Nsec/meter before planing when the velocity is less than 6m/s and b2=50Nsec/m when velocity is aboce 6m/s.
The race is 500m long, which sailboat will be leading at the end of the race?
I assume that the method of solution will be to complete the equations of motion for both then sub them for the race length but the problem that is getting me is the different constants for different times. Do I need the heavyside function or something to get this set-up.
The solution to this question involves solving the equations of motion for both boats using the given information. The equation of motion for each boat is F = ma + bv, where F is the net force, m is the mass, a is the acceleration, b is the proportionality constant, and v is the velocity. Since the wind applies a constant force of 650N, we can substitute F = 650N in each equation. For Boat A, the equation of motion is 650N = 60kg(a) + 80Nsec/m(v) when v < 5m/s and 650N = 60kg(a) + 60Nsec/m(v) when v > 5m/s. For Boat B, the equation of motion is 650N = 60kg(a) + 100Nsec/m(v) when v < 6m/s and 650N = 60kg(a) + 50Nsec/m(v) when v > 6m/s.Once these equations are solved, they can be integrated with the initial conditions (initial velocity = 2m/s) to obtain the position of both boats over the 500m race. Whichever boat has a higher final position at the end of the race will be leading.
27K
14K
17K
