Endomorphism Compositions and Injectivity/Surjectivity Criteria for Groups
  • Context: Graduate
  • Thread starter Thread starter Data
    Composition
The discussion revolves around the properties of endomorphisms in group theory, specifically addressing the conditions under which the composition of two endomorphisms results in an automorphism. Participants explore whether the injectivity of one endomorphism and the surjectivity of the other can be inferred from this composition being an automorphism, with a focus on both finite and infinite groups.
  • One participant presents the problem of proving that if the composition of two endomorphisms is an automorphism, then one must be injective and the other surjective, particularly in the context of infinite groups.
  • Another participant argues that if the first endomorphism is not surjective, then the second cannot be injective, suggesting a relationship between the two properties.
  • A counterexample is proposed using the group formed by infinite copies of Z2, where the endomorphisms do not satisfy the injectivity and surjectivity conditions despite their composition being an automorphism.
  • Another participant suggests that the initial assumption might be reversed, proposing that the first endomorphism must be surjective and the second must be injective instead.
  • One participant asserts that while the finite case supports the original claim, it does not hold for infinite groups.
  • The original poster later clarifies that the misunderstanding stemmed from a difference in notation regarding the composition of functions, leading to a trivial result regarding bijections.
Participants express disagreement regarding the implications of the composition of endomorphisms, with some asserting that injectivity and surjectivity cannot be guaranteed in infinite groups. The discussion remains unresolved regarding the validity of the original claim in the context of infinite groups.
Participants note that the results may depend on the definitions used for the composition of endomorphisms, and the distinction between finite and infinite groups plays a significant role in the discussion.
Data
Hi. I haven't been here in a while, but I've just run across a question that I can neither find an easy counterexample for nor prove easily. Here it is:
Let G be a group, and [itex]\alpha : G \rightarrow G[/itex] and [itex]\beta : G \rightarrow G[/itex] be endomorphisms. Assume that [itex]\alpha \circ \beta[/itex] is an automorphism of [itex]G[/itex]. Prove that [itex]\alpha[/itex] is injective and [itex]\beta[/itex] is surjective.
If G is finite the result is easy. I do not know how to prove it for infinite groups, nor have I been able to find a simple counterexample (it's easy to construct automorphisms that are compositions and for which the composing functions don't fill the injective/surjective criteria above, but I can't find a composition of homomorphisms that do it).
Thanks in advance for your help.
If b is not surjective, then a is not injective, since a(b(G)) = G and b(G) < G, so if a maps a subset of G to all of G, then the rest of G, G - b(G), must be sent to stuff that a has already sent b(G). If a is not injective, then there are g, h in G such that a(g) = a(h). If b is surjective, then b(G) = G and it contains g and h, so a*b will not be injective and hence not an automorphism. The two results above give us that a is injective iff b is surjective. I'm not sure that this is useful.
Now are you being asked by some textbook to prove the result? If so, we shouldn't waste time looking for a counterexample, but is it possible that what you're being asked to prove is false?
Take G to be the product of infinite copies of Z2. Define a by:
a((x1, x2, ...)) = (x2, x3, ...)
Define b by:
b((x1, x2, ...)) = (0, x1, x2, ...)
a*b = I (identity) so it is clearly an automorphism. But a is not injective since it maps (0, x2, x3, ...) to the same place as (1, x2, x3, ...). b is not even surjective either, since it doesn't map anything to the 50% of G that starts with a 1 (using the figure "50%" rather loosely). And a and b are indeed endomorphisms, because whether you add numbers then push down (or pull forward), or whether you push down (or pull forward) and then add the numbers after doesn't matter. Unless there's some careless error in the above, it provides a counter-example to the given statement when |G| is not finite. Note that this agrees with the first result I gave that a is injective iff b is surjective. That result didn't really help, but I guess it gives me a little comfort because I haven't rigourously checked that my counterexample works.
I think it should be the other way around: [itex]\alpha[/itex] will necessarily be surjective, since [itex]G=\alpha(\beta((G)))\subset \alpha(G)[/itex] and [itex]\beta[/itex] will necessarily be one-to-one, since otherwise there would be two elements of G being sent to the same element under [itex]\alpha \circ \beta[/itex].
Yes, it is trivially true that a must be surjective and b must be injective. In the finite case, you can prove the not-so-trivial result that a must be injective and b must be surjective. In the infinite case, that becomes false.
Hi again. I'm sorry that I abandoned this thread, first of all! Even though it's been so long, I figure that I had better post this for completeness' sake.
The problem turned out to be a misunderstanding. The source was writing compositions in the opposite way to that in which I (and everyone else I know) does, so it was actually just asking for the trivial result that [itex]\alpha \cdot \beta[/itex] is a bijection implies [itex]\alpha[/itex] is surjective and [itex]\beta[/itex] is injective.
And I don't see anything wrong with the counterexample posted above, either.
Thanks again!
