 Quote by NutriGrainKiller
Einstein said that light accelerates instantaneously to 299,792,458 m/s. He also said that if you were to hop on a bike and petal to 9/10ths the speed of light, the light will still travel away from you at the speed of light. This makes sense, but what I don't understand is what determines that speed,
But then again, I ask a complicated question, I should get a complicated answer….so me asking to put this in layman’s terms is like telling you to convert apples to oranges. Replies are greatly appreciated
the answer isn't complicated, but there is some insight required. i might suggest that you look at the Wikipedia article on Planck units:
http://en.wikipedia.org/wiki/Planck_units . that speed of propagation (of either E&M or gravity) of 299,792,458 m/s is a number that is totally dependent on the units (meter and second) that it is expressed it. but when we measure
anything, we ultimately only measure dimensionless numbers. (When one commonly measures a length with a ruler or tape-measure, that person is actually counting tick marks on a given standard or is measuring the length relative to that given standard, which is a dimensionless value. It is no different for physical experiments, as all physical quantities are measured relative to some other like dimensioned values.) that numerical value of 299,792,458 is
only a consequence of the units of length and time we humans have decided use.
In Planck units the speed of light is always 1 Planck length per Planck time. if some God somehow changes [tex] c [/tex], it's still 1 Planck length per Planck time. so the question is: "why is there 5.39121 x 10
-44 seconds in a Planck Times and why is there 1.61624 x 10
-35 meters in a Planck length? in other words, why did we choose our unit time and unit length to have the reciprocals of those two numbers -- to have that many Planck times in a second and to have that many Planck lengths in a meter?
now, i don't know
why an atom's size is approximately [tex] 10^{25} l_P \ [/tex], but it is, or why biological cells are about [tex] 10^{5} \ [/tex] bigger than an atom, but they are, or why we are about [tex] 10^{5} \ [/tex] bigger than the cells, but we are and if any of those dimensionless ratios changed, life would be different. but if none of those ratios changed, nor
any other ratio of like dimensioned physical quantity, we would still be about as big as [tex] 10^{35} l_P \ [/tex], our clocks would tick about once every [tex] 10^{44} t_P \ [/tex], and, by definition, we would always perceive the speed of light to be [tex] c = \frac{1 l_P}{1 t_P} \ [/tex] which is the same as how we do now, no matter if it could conceptually be changed to another speed.
