Magnets & Gravity: Making a Magnet Rotate
  • Context: High School
  • Thread starter Thread starter zelldot
    Gravity Magnets
The discussion revolves around the feasibility of making a magnet rotate around a center point using other magnets. Participants explore concepts related to magnetic forces, orbits, and the potential for magnetic levitation and motion.
  • Some participants inquire whether it is possible to have a magnet orbit another magnet, similar to the Moon's orbit around the Earth.
  • One participant suggests that electric motors achieve rotation, while questioning the feasibility of using fixed magnets to create such motion.
  • Another participant argues that achieving a magnetic orbit would require balancing forces, and that simply using repulsive or attractive forces from magnets would not suffice for creating an orbit.
  • There is a proposal that if the motion of the magnets is restricted to a plane, it might be theoretically possible to achieve a form of magnetic orbit, although it would be less stable than gravitational orbits.
  • Participants discuss the concept of using magnets to make an object float and spin, with references to existing technologies like Maglev and superconductors.
  • One participant emphasizes that while energy can be imparted to a system, magnets cannot perform work on their own, indicating a limitation in their use for continuous motion.
Participants express differing views on the possibility of creating a magnetic orbit, with some suggesting theoretical methods while others highlight limitations. There is no consensus on the feasibility of making a magnet rotate around another magnet or achieving self-sustaining motion with magnets.
Participants note the complexities involved in magnetic interactions, such as the need for additional forces to create orbits and the instability of magnetic systems compared to gravitational ones. There are also references to the limitations of magnets as energy sources.
zelldot
is it posible to make a magnet rotate around a center point, with the use of other magnets?
Electric motors do that. Or do you mean fixed magnets? If you mean by fixing magnets to an apparatus at specific angles to make another magnet spin, no, it can't be done.
Do you mean to ask if it is possible to have a magnet orbit another magnet as the Moon orbits the Earth?
If so, I don't think that it is possible without magnetic monopoles.
you can place the magnets how you want, use anything you want, eg, string tieing up a magnet, whilt there is a magnet in the center, and yes i do want to make a magnet orbit anouther magnet or object... like the moon orbits the earth
The moon does not exactly orbit the earth, they orbit each other or I guess more properly, a common center of mass.
If you mean that you want to say balance the repulsive force of two magnets with some force or forces acting in the opposite direction, yes, you just have to engineer that situation.
But without some force other than their repulsive force (or attractive if you go the other way) you won't create an orbit, perhaps tying two magnets together on a stinger will create some straight line relationship but then an orbit requires more than that.
Isn't he askeing if the tangential force would cancel the attractive force, just like a gravitational orbit? Could you not set two magnets in "magnetic orbit" around each other?
Let's see, you would have to restrict their motion to a plane so that you could eliminate the dipole problem.
Now, magnets attract as the cube of their separation, right? And you'd have the poles acting at both ends (N-S on top and S-N on the bottom), so your force would be 2r^3.
Still, you should be able to (in theory) impart enough velocity upon them to cancel the attractive force, putting them in orbit about each other.
Of course, it would be much more unstable than a gravitational orbit, since any perturbations are cubed rather than squared.
how could i make and object float and spin by them selves, using magnets, or even just float.
You haven't heard about Maglev, or even seen those too-popular demonstration of superconductors levitating in magnetic fields?
Zz.
You should know that you won't be able to get magnets to do "work". You can impart energy to the system (just like you could start a pail of water on a string swinging around your head) but it won't do it on its own. Magnets are not a source of energy.
  • · Replies 22 ·
