| New Reply |
The Nuclear Power Thread |
Share Thread | Thread Tools |
| Jun3-09, 09:08 PM | #120 |
Financially bad is an understatement. If you consider Inertial Confinement Fusion at the Lawrence Livermore National Laboratory, you are probably talking electricity at over $10/kWh. Here's why. For openers, we are told that they must detonate at least the equivalent of one gallon of gasoline/sec. with a repetition rate of one repetition/sec i.e. not over multiple chambers (as presented in a cartoon on Charlie Gibson).
Let me get this straight hmm 100,000,000 degrees C (The temperature of implosion fusion by lasers) going to -260 degrees C in less than one second (the temperature of a deuterium/tritium sand grain). Sounds realistic doesn't it? Let's take that measly one gallon of gasoline/sec. For openers, a big coal fired plant may need as much as 17,000 tons of coal/day. That works out to 400 pounds/sec. Sounds like a lot more energy than a gallon of gasoline, so that gallon of gasoline/sec. is a pretty small base load plant. As for the gallon of gasoline: One pound of gasoline has the explosive equivalent of 15 pounds of dynamite. So a gallon of gasoline going off every second is the explosive equivalent of 100 pounds of dynamite going off every second. How do we capture the explosive power of 100 pounds of dynamite going off every second? Here are the steps: 1)Input, 2)Compression, 3)Ignition, 4)Exhaust. Doesn't this sound like an internal combusion engine? Now for the engineering details conveniently omitted by the LLNL people. How do you isolate the lasers from the force of a 100 pound stick of dynamite going off a few feet away? Suppose the laser zigs when it should zag and the implosion front of the pellet is all screwed up. One second it is a 100 pound stick of dynamite, the next a 10 pound stick of dynamite. This would require going to some kind of 1000 ton + flywheel to even out the detonations just like on a John Deere tractor. The next thing that is required is that you will need Star Wars in a bottle. How do you get a particle the size of a sand grain into the chamber, then lock onto a moving target and detonate it with 196 lasers simultaneously? We can't even hit something as big as a missile yet we can lock onto a moving sand grain and hit it synchronously with 196 lasers! Each chamber will need at least a minute to cool off and the need to damp the lasers motion, so that the sand grain doesn't vaporize upon entering the chamber. This means that there will need to be at least 60 times the numbers of lasers and chambers suggested by LLNL. Toroidal fusion will never be practical because it requires enormously expensive, incredibly complicated machinery (Murphy's Law considerations) that requires fuel so expensive that it is cheaper to burn one carat diamonds in the reactor with enormous numbers of cooling towers. This competes with simple, rapidly improving technology with free fuel and no cooling towers (Wind, solar and geothermal---bio fuels are cheap and the Integral Fast Reactor is far more competitive). After 30 years, they can barely sustain the plasma and they still haven't reached break ever when the energy of the magnets is considered. News Flash! They don't know how to deal with the exhaust from the plasma fusion products! Did the Department Of Energy do a Draft Environmental Impact Statement and a Final Environmental Impact Statement when they decided to fund the hot fusion program at MIT as required by the National Environmental Policy Act of 1969? Who wanted the hot fusion program? As a geologist, I'd love to spend billions of dollars putting a geothermal system in every single family residence having over 1/2 acre. This would put a whole lot of geologists to work. If I was a chemist, I'd like to build better batteries, more fuel efficient cars, better insulation, high temperature superconductivity and such things as better insulators, semiconductors, etc. If I was a biologist, I'd love to build cellulose bio fuel plants all over the US and have thousands of ponds producing hydrogen-producing algae. If I was an atmospheric scientist, I'd love to put wind mills everywhere. Did the DOE get input from other branches of the sciences when they decided to fund the hot fusion program at MIT? So why do we have a hot fusion program? Because the gool 'ole boys network at DOE decided to provide the underfunded physicists at MIT with a gravy train lasting 35 years with another 35 years in the offing (Ask any hot fusion scientist when hot fusion will be commericially viable, it is always, "Thirty years from now." |
| Jun11-09, 08:26 PM | #121 |
Admin
Archive of Previous Symposia
http://www.world-nuclear.org/sym/subindex.htm The papers are fairly general and deal with the industry, trends, fuel cycle issues, waste and other related topics. |
| Jul24-09, 05:09 PM | #122 |
Admin
If one is studying nuclear engineering, or is planning to do so, or planning a career in nuclear engineering, then this is relevant.
http://www.ne.doe.gov/pdfFiles/rpt_N...es_Sep2008.pdf Lot's of other good reports here - http://www.ne.doe.gov/ An overview of new and proposed NPPs http://www.world-nuclear.org/info/inf08.html |
| Aug15-09, 04:15 PM | #123 |
| Aug15-09, 04:23 PM | #124 |
| Aug15-09, 05:26 PM | #125 |
It seems to me that TMI is about the worst possible accident that can happen to a modern LWR. Am I correct in that or can anyone reasonably postulate a worse accident? If so, agreed that the risk is low, but when you have over 100 commercial plants operating 30+ years each and the worst case accident, which occurs only once over that period, is ¼ the value of one plant, how can you argue that “unfortunately the cost is high”? |
| Aug17-09, 10:18 AM | #126 |
http://depletedcranium.com/why-i-hat...nrc/#more-2748 Also you should note that the Probabilistic Risk Assessment on the new Westinghouse Ap1000 is hundred times less likely to have a core meltdown than a 2nd generation plant. http://www.asmeconferences.org/ICONE...ntsBeBuilt.pdf The PRA starts on page 23. |
| Aug17-09, 08:33 PM | #127 |
Assumptions, using 2007 $: Cost TMI-2 = 2544 million $ Cost of clean up = $973, over 12 years, use 1985 for adjustment http://www.ans.org/pi/resources/spto...i/cleanup.html Inflation adjustment from 1985 = 1.93 http://www.usinflationcalculator.com/ Clean-up of TMI-2 as a fraction of plant cost = 973*1.93/2544 = 0.74 So, restating my earlier post: If so, agreed that the risk is low, but when you have over 100 commercial plants operating 30+ years each and the worst case accident, which occurs only once over that period, is 3/4 the value of one plant, how can you argue that “unfortunately the cost is high”? And as you point out, and my gut feeling is, even that small overhead loss is way over stated. |
| Aug24-09, 12:24 AM | #128 |
| Sep9-09, 01:35 AM | #129 |
Special section on in the Sept 8 edition titled "The New Nukes"
Temp link: The article is lengthy, covering many of the topics up thread. To start, I wanted to summarize the various cost figures cited through the article:
Summary of experts quoted in the article: Revis James, EPRI Ronaldo Szilard, Idaho National labs Amir Shakarami, Exelon VP Tom Cochrane, NRDC |
| Sep9-09, 01:09 PM | #130 |
I have been very pleased with the construction updates I've seen from Sanmen. I was inclined to write off the modular design stuff as Westinghouse marketing hype, but the actual results are impressive. As I recall, one of the pictures I saw was the whole control room being lifted in place as a single module. By the time we start building our AP1000s, we will be dealing with a proven design and not have to deal with FOAK issues. |
| Sep9-09, 01:36 PM | #131 |
Admin
The cost of concrete and steel is a big factor in current capital costs, as well as labor, as is interest. The Chinese government would certainly be more inclined to subsidize NPPs than would the US government. |
| Sep9-09, 03:26 PM | #132 |
| Sep9-09, 03:53 PM | #133 |
Admin
The nuclear industry is very competitive, but it is very expensive and the margins are often thin. |
| Sep9-09, 04:05 PM | #134 |
| Sep9-09, 05:47 PM | #135 |
Admin
The US market is different. I don't see the same deals being done in the US, because W, AREVA and Mitsuibishi are the primary PWR suppliers - and they can't afford to lose money here. Besides the US DOE (Uncle Sam) is supposed to kick in some subsidies (direct and indirect). |
| Sep11-09, 03:57 PM | #136 |
http://amgroupes.fr/admin/compte_rendus/195_compte_rendu.pdf The reason that the Chinese got a good deal on the AP1000 is that they ordered a 100 of them. The most any US utility company ordered is 2. I've suggested on my blog that Congress change the charter of the TVA so they can build nuclear power plants anywhere in the United States. Maybe they could get some economies of scale also. BTW on the question of what government is providing loan guarantees for these reactors, the answer is the United States. http://www.world-nuclear.org /info/inf63.html The US, French and Russian governments were reported to be giving firm support as finance and support arrangements were put in place. The US Export-Import bank approved $5 billion in loan guarantees for the Westinghouse bid |
| New Reply |
| Thread Tools | |
Similar Threads for: The Nuclear Power Thread
| How do I become a Nuclear Engineer? (Split from Canadian Engineering Thread) | Nuclear Engineering | 16 | ||
| What is the link between nuclear weapons and nuclear power stations? | Nuclear Engineering | 19 | ||
| oil,nuclear power | General Discussion | 21 | ||
| Law against nuclear power? | Nuclear Engineering | 47 | ||
| nuclear engineers thread | Nuclear Engineering | 15 | ||
