Calculating Forces and Acceleration in Motion Problems
  • Thread starter Thread starter airelemental135
    Law Motion
The discussion revolves around calculating forces and acceleration in motion problems, specifically involving a pellet, a fish, and a baseball. Participants are exploring concepts related to kinematics and dynamics.
  • Mixed
  • Participants are attempting to apply kinematic equations to solve for acceleration and force in various scenarios. There are questions regarding unit conversions, the setup of reference systems for forces, and the interpretation of motion when an object comes to rest.
Some participants are providing guidance on unit conversions and the importance of defining reference systems. There is an ongoing exploration of the calculations related to the baseball's motion and the forces involved, with no clear consensus reached yet.
Participants are discussing the implications of the problem statements, including the need to clarify initial and final velocities, distances, and the effects of forces in different directions. There are indications of confusion regarding the interpretation of the baseball's motion and the resulting calculations.
airelemental135
8. What average force is needed to accelerate a 7.00-gram pellet from rest to 175 m/s over a distance of 0.700 m along the barrel of a rifle?
9. A fisherman yanks a fish out of the water with an acceleration of 4.5 m/s^2 using very light fishing line that has a "test" value of 22 N. The fisherman unfortunately loses the fish as the line snaps. What can you say about the mass of the fish?
10. A 0.140-kg baseball traveling 45.0 m/s strikes the catcher's mitt, which, in bringing the ball to rest, recoils backward 11.0 cm. What was the average force applied by the ball on the glove?3
I tried doing number 8 on my own.
vfinal^2=vinitial^2 + 2ad
175m/s=0^2 + 2a(0.700m)
a= 125m/s
F=ma
F=(7.00g)(125 m/s)
F=875N
Is this correct>? How do you do the others?
for number 8 - CAREFUL about the units. Mass is ALWAYS (make it a habit to convert it to) Kilograms.
for number 9 - Well if you are lifting a weight upward by a string, what are the forces that the weight would feel? ANd since this is upward motion you need only to care about those poiting upward and downward. Create a reference system in which upward is positive and downward is negative (the opposite is fine as well, as long as you are consistent with this reference system). Try to form something like this:
Sum of all the forces = Net Force
ANd test means tension here.
For number 10 - What is hte initial velocity, final velocity, distance it traveled before it came to a stop, thus can you find the acceleration? And find the force. Since it is a vector specify the direction, was the force in the original direction that the ball was going or the opposite?
It says the baseball recoils backward 11.0 cm. Is that the distance?
yes.. and again careful with the units
i used the formula vfinal^2=vinitial^2 + 2ad to calculate the velocity, and got 0. Is this correct? if so, the force would end up being 0?
i meant to calculate the acceleration
hgow did u get zero? What is the value of v1? and the value of distance?
v initial i put is 45 m/s, v final is 45 m/s distance is .11m
what should it be?
Read the question. What happens to the ball when it is caught in the met?
it bounces back .11 meters
oh so vfinal should be 0? because it says its at rest when it hits the mitt
Is this right now?
Vfinal ^2 = vinitial ^2 + 2ad
(0)^2=(45.0m/s)62 + 2a(.11m)
0m/s=2025m/s + .22a
a=-9205m/s^2
F=ma
F=(0.140kg)(-9205m/s^2)
F=-1289N
right?
are you still there stunner5000pt ?
  • · Replies 24 ·
  • · Replies 38 ·
