What Is the Force on a Square Roof During High Winds with Bernoulli's Equation?
The force exerted on a square roof during high winds can be calculated using Bernoulli's Equation. In this discussion, a square roof with a side length of 22.0 m and wind speed of 29.0 m/s resulted in a calculated force of 246,356 N, using an air density of 1.21 kg/m³. The formula applied was F = (Pi - Po)A = 0.5 d V², where d represents the air density and V the wind speed. The calculation confirms the significant impact of wind pressure on structural integrity.
  • Understanding of Bernoulli's Equation
  • Knowledge of atmospheric pressure concepts
  • Familiarity with basic physics of forces
  • Ability to perform calculations involving density and area
  • Research the implications of wind load on building design
  • Learn about different methods for calculating wind pressure on structures
  • Explore advanced applications of Bernoulli's Equation in fluid dynamics
  • Investigate building codes related to wind resistance
Engineers, architects, and construction professionals involved in structural design and safety assessments during high wind events.
2Pac
During high winds, the atmospheric pressure inside a house may blow off the roof because of the reduced pressure outside. Calculate the force on a square roof of side 22.0 m if the wind speed over the roof is 29.0
i used bernoulli's equation and got an answer of... 246356N
i used 1.21 as the density of air. could someone check my work please?
anyone care to try?
Pi = Po + 0.5d V^2
F = (Pi-Po)A = 0.5 d V^2 ; d is the density = 1.293 kg/m^3
  • · Replies 16 ·
15K
11K
  • · Replies 20 ·
