Kinematics Problem 1: Determining Acceleration and Maximum Speed in a Race
The discussion revolves around a kinematics problem involving two sprinters, A and B, who finish a race simultaneously after accelerating uniformly and then maintaining maximum speed. The participants are tasked with determining the acceleration and maximum speed of each sprinter based on given variables.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to break down the race into phases, using kinematic equations to analyze the motion of both sprinters. They express uncertainty about their logic and seek validation of their approach.
  • Some participants question the formulas being used and suggest alternative equations for uniform acceleration. They discuss the need to isolate acceleration and consider the time spent at constant velocity.
  • There are inquiries about how to manipulate the resulting equations to solve for acceleration.
The discussion has seen participants offering guidance on the application of kinematic equations and the breakdown of the problem into phases. While some participants express confidence in their understanding, others continue to seek clarification on specific steps and calculations.
Participants are working under the constraints of expressing their answers in terms of specific variables related to the race, including distance, total time, and individual acceleration times.
an_mui
Problem 1.
In a race a distance d long, A and B cross the finish line in a dead heat, both taking a time T. Accelerating uniformly, A takes a time ta and B a time tb to attain maximum speed, which they maintain for the rest of their race.
a) what is the acceleration of each sprinter?
b) what are their respective maximum speeds?
For both questions, express your answer in terms of d, T, ta and tb.
This is what I've done so far.. my logic is probably all wrong but any help is appreciated.
1. First, I think that the equation of A and B will be very similar (only ta, tb and maximum speeds are different).
2. I use the kinematic equations, and divide the race of A into two halves. The first half is when A is accelerating uniformly.
Phase 1
V2 = v1 + a(delta d)^2
V2 = a(delta d)^2
the distance traveled in phase 1 would be (v2 + v1)/2 x ta
d1 = (v2/2)ta
Phase 2
d2 = v2(T - ta)
Can someone tell me if my logic up to this point is correct?
you're not using the correct formula it is
[tex]v_{2}^2 = v_{1}^2 + 2ad[/tex]
good idea doing it in phases i did it the same way. So for the first leg of A you have uniform acceleration where u use the above formula
For the second leg of A you have constant velocity with time where time is
T - Ta (do you see why?) the total time - the time taken to reach is the time A will be at cosntant velocity. Now Add the distances from both phases. And isolate for aceleration. Do the same for B.
Sorry I am stuck again.
After I added the two phases togehter, I am left with the following equation
dtotal = (v2)^2 / 2a + v2 ( T - Ta)
how would i solve for a?
I assume what you have is,
[tex]d_{total} = \frac{v_2^2}{2a} + v_2 ( T - T_a)[/tex]
where a is the acceleration during the first phase and v2 is the final velocity, with v1 = 0.
you will have gotten v2 = aTa - just substitute.
Got the help I needed, thanks!
Yes, you did it right - those answers are correct.
btw, your answer for the acceln might look neater if the t1 was taken out as a factor :smile:
[tex] a = \frac{2d}{t_{1}(2T - t_{1})}[/tex]
thank you very much! I really appreciate your help =)
  • · Replies 20 ·
