Thread Closed
Re: Have space-time and the metric tensor finally run their course?
Share Thread Thread Tools
Sep27-05, 02:38 PM   #1
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>In article &lt;l789j1932b62vqgcnsudausqis0q70i1hd@4ax.com&gt;, John C. Polasek\n&lt;jpolasek@cfl.rr.com&gt; wrote:\n\n[snip]\n&gt; The ei on the input vector have a 1:1 neat correspondence with 1 1 1\n&gt; 1, the first component being representative of time. The output dual\n&gt; vector likewise must have a 1:1 correspondence, it\'s not just 4\n&gt; numbers and the correspondence now is e0 = -1 as in -1 1 1 1.\n&gt; What is there you can say about this covector, when our oriignal basis\n&gt; is 1111. What are we to make of this misfit -1111? The first element\n&gt; must be time and it\'s reversed.\n&gt; Admit that you would rather have it other, but "we\'re getting by OK".\n\nNo, I wouldn\'t "rather have it other", because I know that timelike\nvectors are different from spacelike vectors, and as I\'ve said the\n"misfit" you keep complaining about reflects precisely that physical\nreality.\n\nGR and SR do not claim that time is "just another dimension". The\ndifference is built into the structure of the theories from the start.\nWhat they *do* insist on is that different observers are entitled to\ndifferent definitions of time, just as different observers are entitled to\ndifferent definitions of "left-right, forwards-backwards, up-down". What\nthey do *not* allow is anyone\'s "left-right" axis to be someone else\'s\n"future-past" axis.\n\n&gt; Greg Egan wrote:\n&gt;\n&gt; &gt;What follows from this is that if you feed the vector v as an argument to\n&gt; &gt;its own dual vector, the number you get is:\n&gt; &gt;\n&gt; &gt; -(v^0)^2 + (v^1)^2 + (v^2)^2 + (v^3)^2\n&gt; &gt;\n&gt; &gt;i.e. the quadratic form that gives the squared magnitude of v. The minus\n&gt; &gt;sign on the first coordinate allows there to be three distinct classes of\n&gt; &gt;vectors: those for whom this quadratic is -ve, +ve or zero. This\n&gt; &gt;corresponds very usefully to three classes of vectors observed in\n&gt; &gt;physical reality: timelike, spacelike, and lightlike or null.\n&gt; &gt;\n&gt; &gt;There are no mathematical or logical difficulties following from this,\n&gt; &gt;and rather than GR trying to pretend that there\'s nothing special about\n&gt; &gt;time, the mathematical aspect you complain about is actually what\n&gt; &gt;supports the distinction between timelike and spacelike vectors.\n&gt;\n&gt; Excuse me for not following up your original thread because I thought\n&gt; it would be easier to prove the defect in g. And it is simple: g00\n&gt; should be e0*e0. Don\'t tell me it is because a defective matrix was\n&gt; used to make the covector. 3D + time is far superior to STR and GTR,\n&gt; getting all the results without the clutter.\n\nI have no idea what you mean by "e0*e0" -- is e0 meant to be a vector\nhere? A component of a vector? What kind of product is "*" here?\n\nYou\'ll get a more productive conversation if you agree to use some\nstandard notation which makes things clearer: distinguish upper and lower\nindices, which can be done in ASCII by prefixing them with ^ and _.\n\nWhat *should* be true, and is true, is that:\n\ne_0 . e_0 = g_{00}\n\ni.e. the dot product of the timelike basis vector with itself will be\nequal to g_{00}. This follows from the definition of the dot product in\nterms of a general metric; for vectors v and w it is:\n\nv . w = v^i w^j g_{ij}\n\nwhich in the case v=w=e_0 becomes:\n\ne_0 . e_0 = delta^i_0 delta^j_0 g_{ij}\n= g_{00}\n\nAnd what is e_0 . e_0 ? Because e_0 is a timelike vector, it must be -1.\nThis has got nothing whatsoever to do with time "running backwards" or\nhaving "reversed polarity". It is about timelike vectors being different\nfrom spacelike ones.\n\nYou are free to prefer some other formalism, if you can actually make it\nmathematically consistent and produce predictions that match up with\nphysical reality. But every time you assert that there\'s a "defect" in\nthe use of a metric tensor just because you have some purely aesthetic\ndifficulty with the fact that its signature is {-1,1,1,1} rather than\n{1,1,1,1}, you\'re just demonstrating that you don\'t understand general\ntensors. There\'s a world of difference between you finding something\nannoying, and it being logically inconsistent or self-contradictory. The\nthings that you keep asserting that "must be true" about tensors are\nsimply wrong.\n\nPossibly you read some definitions in a textbook that was dealing only\nwith tensors in the context of purely spatial dimensions. If, for\nexample, you\'re dealing with a manifold that is embedded in ordinary\nEuclidean space, then you can write a general point of that manifold as a\nvector in the embedding space as a function of the coordinates on the\nmanifold: p(x_1,....,x_n) in R^m, where R^m is the Euclidean space in\nwhich the manifold is embedded. Then there are coordinate basis vectors\n*for the manifold*, in R^m:\n\ne_i = dp/dx_i\n\nand the metric has coordinates in this basis of:\n\ng_{ij} = e_i . e_j\n\nwhere "." is the conventional Euclidean dot product in R^m.\n\nWhat\'s happening here is that the metric of the embedded manifold is\ninduced by the flat Euclidean metric on R^m. With this method, you can\nfind, for example, the appropriate metric to use on the surface of the\nEarth.\n\nWhat this won\'t ever give you is a manifold with timelike dimensions. But\nGR does not assert that spacetime is embedded in a larger Euclidean space,\nso don\'t expect formulas and assumptions from a limited version of tensor\ncalculus that deals with that context to apply to the more general\nsituation.\n\n--\nGreg Egan\n\nEmail address (remove name of animal and add standard punctuation):\ngregegan netspace zebra net au\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>In article <l789j1932b62vqgcnsudausqis0q70i1hd@4ax.com>, John C. Polasek
<jpolasek@cfl.rr.com> wrote:
[snip]
> vector likewise must have a 1:1 correspondence, it's not just 4
> numbers and the correspondence now is [itex]e0 = -1[/itex] as in [itex]-1 1 1 1[/itex].
> is 1111. What are we to make of this misfit [itex]-1111[/itex]? The first element
> must be time and it's reversed.
> Admit that you would rather have it other, but "we're getting by OK".
No, I wouldn't "rather have it other", because I know that timelike
vectors are different from spacelike vectors, and as I've said the
reality.
they do *not* allow is anyone's "left-right" axis to be someone else's
"future-past" axis.
> > [itex]-(v^0)^2 + (v^1)^2 + (v^2)^2 + (v^3)^2[/itex]
> >vectors: those for whom this quadratic is [itex]-ve, +ve[/itex] or zero. This
> >and rather than GR trying to pretend that there's nothing special about
> should be [itex]e0*e0[/itex]. Don't tell me it is because a defective matrix was
> used to make the covector. [itex]3D +[/itex] time is far superior to STR and GTR,
I have no idea what you mean by "[itex]e0*e0[/itex]" -- is e0 meant to be a vector
You'll get a more productive conversation if you agree to use some
indices, which can be done in ASCII by prefixing them with [itex]^[/itex] and [itex]_[/itex].
[tex]e_0 . e_0 = g_{00}[/tex]
equal to [itex]g_{00}[/itex]. This follows from the definition of the dot product in
v . [itex]w = v^i w^j g_{ij}[/itex]
which in the case [itex]v=w=e_0[/itex] becomes:
[tex]e_0 . e_0 = \delta^i_0 \delta^j_0 g_{ij}= g_{00}[/tex]
And what is [itex]e_0 . e_0 ?[/itex] Because [itex]e_0[/itex] is a timelike vector, it must be -1.
physical reality. But every time you assert that there's a "defect" in
difficulty with the fact that its signature is [itex]{-1,1,1,1}[/itex] rather than
[itex]{1,1,1,1},[/itex] you're just demonstrating that you don't understand general
tensors. There's a world of difference between you finding something
simply wrong.
example, you're dealing with a manifold that is embedded in ordinary
manifold: [itex]p(x_1,....,x_n)[/itex] in [itex]R^m,[/itex] where [itex]R^m[/itex] is the Euclidean space in
[itex]*for[/itex] the manifold*, in [itex]R^m:e_i = dp/dx_i[/itex]
[tex]g_{ij} = e_i . e_j[/tex]
where "." is the conventional Euclidean dot product in [itex]R^m[/itex].
What's happening here is that the metric of the embedded manifold is
induced by the flat Euclidean metric on [itex]R^m[/itex]. With this method, you can
Earth.
What this won't ever give you is a manifold with timelike dimensions. But
so don't expect formulas and assumptions from a limited version of tensor
situation.
Greg Egan
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Thread Closed
Thread Tools
Similar Threads for: Re: Have space-time and the metric tensor finally run their course?
Thread Forum Replies
Re: Have space-time and the metric tensor finally run their cou General Physics 0
Re: Have space-time and the metric tensor finally run their cou General Physics 1
