How Much Current Is Needed for a Solenoid to Generate a Specific Magnetic Field?
  • Thread starter Thread starter jena
    Current
The discussion focuses on calculating the current required for a solenoid to generate a magnetic field of 0.385 T. The solenoid in question is 50.0 cm long with a diameter of 1.25 cm and contains 975 turns of wire. The relevant formula used is B = μ₀ nI, where 'n' represents the number of turns per unit length, calculated as n = N/L. The diameter is not directly used in the calculation but is important for ensuring the solenoid is considered long enough for the formula to apply.
  • Understanding of electromagnetic theory, specifically solenoids
  • Familiarity with the formula B = μ₀ nI
  • Knowledge of how to calculate turns per unit length (n = N/L)
  • Basic grasp of magnetic fields and their units (Tesla)
  • Study the derivation and applications of the formula B = μ₀ nI
  • Learn about the characteristics of solenoids and their magnetic fields
  • Explore the impact of solenoid dimensions on magnetic field strength
  • Investigate practical applications of solenoids in electromagnetic devices
Students and professionals in physics, electrical engineering, and anyone interested in the principles of electromagnetism and solenoid design.
jena
Hi,
My Question:
A 50.0-cm long solenoid 1.25cm in diameter is to produce a field of 0.385 T at its center. How much current should the solenoid carry if it has 975 turns of the wire?
I know that I have to use this equation:
B = \mu _0 nI
where I'm stuck at is with the length do I used the how long it is with the diameter or do i just ignore the diameter :confused:
please help
Thank You :smile:
The formula you have written is for a long solenoid such that L >>R, to insure this, I think the dimeter is given, otherwise you have to use general formula for the field.
In this formula 'n' is the number of turns per unit length n = N/L.
  • · Replies 31 ·
