Does Airplane Downwash Reach the Earth's Surface?
  • Thread starter Thread starter Raptor01601
The discussion revolves around the phenomenon of airplane downwash and whether it reaches the Earth's surface, particularly at high altitudes. Participants explore the mechanics of downwash in relation to air viscosity, momentum conservation, and the potential effects on the atmosphere.
  • One participant questions how downwash from an airplane at high altitude reaches the Earth, suggesting that pressure distribution and vortex behavior may play a role.
  • Another participant asserts that downwash is not required to reach the Earth, citing air viscosity as a factor that dissipates downwash at high altitudes.
  • A different participant mentions that while energy can be dissipated, momentum cannot be entirely dissipated and raises the concept of an aircraft leaving a "footprint" in the atmosphere.
  • Some participants discuss the idea that momentum can be "spread out" or transferred by viscosity, leading to a loss of bulk movement in the fluid.
  • There is a mention of how friction against solid boundaries can lead to a loss of momentum and energy, while gravity can also contribute to momentum in certain scenarios.
  • One participant describes the behavior of gas layers and the role of molecular collisions in generating pressure and viscosity, questioning if their understanding is correct.
Participants express differing views on whether downwash reaches the Earth's surface and the implications of momentum and energy dissipation. There is no consensus on the mechanisms involved or the outcomes of downwash behavior.
Participants reference various physical principles, such as conservation of momentum and the effects of viscosity, but the discussion remains open-ended with unresolved aspects regarding the transport mechanisms of downwash.
Raptor01601
I was wondering if you could help me with a question?
How does the down wash from an airplane at high altitude (out of ground effect) reach the earth? It seems to me from looking at various airfoil simulation programs that in 2-D flow *bound vortex only* the pressure distribution aft of the airfoil will return the airflow to the free stream direction, in addition, if you go certain distance above or below an airfoil, you will find a straight streamline. In 3-D flow, I know that the wing tip vortices contain down wash, but they will dissipate due to friction (viscosity). Is it a momentum flow or something from the dissipated vortices that provides the down wash at the surface of the earth?
From conservation of momentum laws, is it required that a down wash reach the earth?
Thank you for your time
No, it's not required that they reach the earth, and you answered the question yourself. Air viscosity will dissipate the downwash entirely if the plane is high enough off the ground.
I know that you can dissipate the energy, turning it into heat, but you can not dissipate the momentum.
Also, I think Prandtl showed that an aircraft at altitude will leave a "footprint" which would be extremely hard to maesure because it would be a really small pressure change over a huge area. I was just wondering what "transport mechanism" brought this "footprint" to earth.
That is incorrect. Momentum and energy are dissipated - or transferred.
As enigma already mentioned - Air viscosity will dissipate the downwash entirely if the plane is high enough off the ground!
If a plane is close enough to the ground, the downwash reach the ground where it will become a lateral flow with some upflow as well, which itself will be dissipated.
Take a look at a B-1 near the surface of a lake - http://www.everything-science.com/index.php?option=com_smf&Itemid=82&topic=1448.msg48989#msg48989 . The effect is quite localized. The disburance is pretty much dissipated at a distance greater than the characteristic dimension, which could be effective diameter or wing span.
QUOTE=Astronuc]That is incorrect. Momentum and energy are dissipated - or transferred.
I thought the rule was that energy is dissipated (turned into heat) by viscosity.
Momentum is "spread out" by viscosity I think that spread out and transferred mean the same thing here.
I realize that you could probably spread out the momentum so much that you no longer have a "bulk movement" of fluid. In which case I guess that the momentum would be transferred (spread out) by diffusion (molecular motion) of the gas.
Does that sound correct?
In free shear flows the momentum is conserved integrating the velocity in all the infinite domain, despites you have the viscous stress acting inside it. But if you have a bounded domain by solid boundaries, the friction against the wall will cause a loose of momentum (transferred to the wall !) and a loose of energy. Boundaries acts as sinks of momentum and energy, when the heat flux and viscosity are enabled. On the other hand, gravity can be a source of momentum, like in a buoyant jet.
Ok..
In a gas, pressure is caused by molecular collisions with each other and with the walls of whatever container they are in. These velocitys are random velocitys in the Vx, Vy, and Vz directions. Temperature is a measure of the average translational kinetic energy.
If you have two different layers of gas sliding past one another, at different velocitys (velocity of the fluid as a whole), you will have friction/viscosity also caused by molecular collsions
Is this correct?
  • · Replies 24 ·
  • · Replies 30 ·
