Sum of Roots of x^3 - mx^2 + nx - 1 = 0
  • Thread starter Thread starter an_mui
    Roots Sum
The discussion revolves around the polynomial equation x^3 - mx^2 + nx - 1 = 0, where the roots are proposed to be m, n, and 1. Participants are exploring the implications of these roots and how to determine their values.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants are examining the relationships between the roots and coefficients, with some attempting to derive conditions for m and n based on the roots. Questions arise regarding the validity of different sets of roots and how to confirm which set satisfies the original polynomial.
The discussion is active, with various interpretations being explored. Some participants suggest that there may be multiple solutions, while others provide reasoning that leads to a singular conclusion about the roots. Guidance has been offered regarding the implications of polynomial division and the relationships between m and n.
Participants are working under the assumption that m, n, and 1 are non-zero roots, and there is a focus on validating the conditions under which these roots hold true. The discussion reflects uncertainty about the completeness of the solutions derived from the polynomial.
an_mui
If m, n, and 1 are non-zero roots of the equation [tex]x^3 - mx^2 + nx - 1 = 0[/tex], then find the sum of the roots
This is what I did..
m, n, 1 are the roots. m and n not equal to 0
f(m) = 0 --> m^3 - m^3 + mn - 1
1 = mn (1)
f(1) = 1 - m + n - 1 = 0
... m = n (2)
Sub (2) --> (1)
[tex]m^2 = 1[/tex]
[tex]m = +/- 1<br /> <br /> since m and n are equal... the roots must be either 1, 1, 1 or -1, -1, 1. The answer on the sheet says the answer is -1. So my question is, how do we determine which roots are the answers. Thanks[/tex]
This might work. If m, n, and 1 are the roots, that means (x-m)*(x-n)*(x-1) = 0. If you multiply this out and substitute the 2 different sets of values for m & n, I'm guessing that only 1 set is valid.
oops nvm it didn't work
looks like there are 2 possible solutions.
There is only one solution. I used long division. If you divide your polynomial by (x-1), you know you should get a quadratic polynomial, but you get:
x² + (1-m)x + (n+1-m) + (n-m)/(x-1)
So you know n - m = 0. This is one useful fact. Now you're left with:
You know that m is a root of this polynomial, so dividing by (x-m) should give a linear polynomial. When you do the long division, you get:
x + 1 + (n+1)/(x-m)
So you know n + 1 = 0. This gives n = -1. Having already got that n - m = 0, you now get m = -1. And you have the other root being 1.
(-1) + (-1) + 1 = -1.
Good one AKG! :redface:
In your very first post, you note that the solutions must be either {1, 1, 1} or {1, -1, -1} and ask how can you tell that only {1, -1, -1} is correct.
If {1, 1, 1} were the roots, then the equation could be written
(x-1)(x-1)(x-1)= 0 but (x-1)(x-1)(x-1)= x3- 3x2+ 3x- 1, not x3- x2+ x- 1 as it should be with m=n= 1.
If {1, -1, -1}, on the other hand, were the roots then the equation could be written (x-1)(x+1)(x+1)= (x2- 1)(x+1)= x3+x2- x- 1 as required.
  • · Replies 17 ·
