Thread Closed
How can I make my electric scooter go faster
Share Thread Thread Tools
Oct2-05, 08:24 PM   #1
I have a 400W electric scooter and it's just too slow. It uses a 400W, 20Ah motor. So I have a few questions:
What is the easiest way to make this thing go faster without changing the controller?
Will I burn the motor out with a 36V battery pack (the pack is 3 twelve volt, twelve amp cells hooled up on paralell--does that make is a 36amp cell?)
Will the increased voltage increase the RPMs of the motor?
I am trying to do this on the cheap, which means changing as little as possible. I have two of these 36V batteries and a charger, so ideally I would like to be able to solve my problem just by using them. Will it work? Or will I thrash the motor to pieces overnight?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
>> Researchers use light projector and single-pixel detectors to create 3-D images
Oct2-05, 09:10 PM   #2
Recognitions:
Bad idea, you're likely to burn out the controller if you apply too high a voltage.
And if your batteries are in parallel then you have increased the current capacity - in other words longevity - not voltage. In series you gain voltage but the capacity remains the same as the weakest cell in the series.
To find a cheap solution, the first thing to establish is if the motor controller allows for a full duty cycle (assuming its a PWM) and/or if it automatically speed limits based on back-EMF. If this were the case, then a simple high-current relay bypassing the controller would allow you to increase the speed for cheap with the existing battery system. The relay by itslef would last a decent while before the inductive kick-back would pit the contacts too much, and you could add a flyback diode to prevent that too.
Otherwise, to go faster you'd need more voltage AND current - in essence more power. And likely a larger controller to handle that, and better cooling for the motor that may need brushes replaced more often and so on.
Oct2-05, 09:54 PM   #3
Recognitions:
Gold Membership Gold Member
You could also, of course, swap the whole drive system from a more powerful bike—motor, batteries, the works. The advantage to that is that everything will already be compatible.
Thread Closed
Thread Tools
Similar Threads for: How can I make my electric scooter go faster
Thread Forum Replies
Prime Number finding Algorithm.How can we make things go faster? General Math 20
I got my Scooter!!! General Discussion 22
Planning to Buy a Scooter General Discussion 100
Ways to make a computer faster (windows) Computing & Technology 12
Can I make my hair grow faster? Biology 13
