How Does Riemann's Translucent Ball Illustrate Complex Plane Shadows?
  • Context: Graduate
  • Thread starter Thread starter Organic
    Ball
The discussion revolves around Riemann's conceptualization of a translucent ball situated above the complex plane and its implications for understanding symmetry in mathematical expressions, particularly the relationship between the functions 1/x and x/1. Participants explore the geometric representation of numbers on the Riemann sphere and the nature of symmetry in this context.
  • Some participants describe Riemann's ball as casting shadows on the complex plane, with specific characteristics of these shadows, such as circles and lines, depending on the position of the light source.
  • One participant questions the meaning of "symmetric" in relation to the functions 1/x and x/1, asking for clarification on the reference point for symmetry.
  • Another participant proposes that if Riemann's ball is reduced to a circle connecting the south pole (0) and north pole (infinity), then 1 is positioned as the midpoint between these two extremes.
  • Concerns are raised about the interpretation of symmetry and the relationship between geometric representations and decimal representations of numbers, with some participants expressing confusion over the concept of a number having "infinitely many digits at the left side of the floating point."
  • There is a reiteration of questions regarding the symmetry of the functions and the existence of a number system that reflects this symmetry.
Participants express differing views on the concept of symmetry in the context of Riemann's ball and the functions discussed. There is no consensus on the interpretation of symmetry or the implications of the geometric representation.
Participants' arguments depend on their interpretations of geometric representations, symmetry, and the nature of number systems, which remain unresolved and may vary based on definitions and assumptions.
Organic
From "ZERO" - The Biography of a Dangerous Idea by Charles Seife:
"Riemann imagined a translucent ball sitting atop the complex plane, with the south pole of the ball touching zero. If there were a tiny light at the north pole of the ball, any figures that are marked on the ball would cast shadows on the plane below. The shadow of the equator would be a circle around the origin. Every point on the ball has a shadow on the complex plane. Every circle on the plane is the shadow of a circle on the ball, and a circle on the ball corresponds to a circle on the plane ... with one exception. a circle that goes through the north pole of the ball, the shadow is a line. The north pole is like the point at infinity."
http://www.nti.co.jp/~kobakan/contents/zero.html#chap5
Edit:
You can find Pdf file of mine on this sybject here:
http://www.geocities.com/complementarytheory/RiemannsBall.pdf
Organic
"1) Can we conclude that 1/x is symmetric to x/1 where
[0,oo] = {x : 0 <= x <= oo}"
What do you mean by "symmetric"? Symmetric with respect to what line or point?
I think what you mean is: Set up an x-y coordinate system in the plane and put a Riemann sphere with its "south pole" at the origin.
Now, look at the great circle on the sphere that is directly above the x-axis. Each point, x, on the positive x-axis corresponds to a point on that circle. If take the radius of the sphere to be R and let &phi; be the angle the line through the center of the sphere and the point x on the x-axis, then &phi;= tan-1(x/R). In particular, x=1 corresponds to the point with &phi= tan-1(1/R). Even more specifically, taking R=1, x= 1 corresponds to the point with &phi= tan-1(1)= 45 degrees. All x from 0 to 1 will correspond to points up to 45 degrees from the vertical. All x from 1 to &infinity; will correspond to points above 45 degrees.
I don't believe that x and 1/x will be "symmetric" in any reasonable sense.
In any case, your second question
If the answer to (1) is yes, then where is the number system of x/1 which is symmetric to 1/x (rational and irrational number systems) and has infinitely many digits at the left side of the floating point?
makes no sense to me at all.
What do you mean by "the number system of x/1 "?
How could any number have "infinitely many digits at the left side of the floating point"?
The Riemann sphere is talking about a geometric representation of numbers- it has no relationship whatsoever with a decimal representation.
Hi HallsofIvy,
Thank you for your reply.
I wrote it again in a clearer way:
If we reduce Riemann's ball to a single circle that goas through south pole (= 0) and north pole (= oo) then 1 is the middle point (on the circle's line) between 0 and oo.
My questions are:
2) If the answer to (1) is yes, then where is the number system of x/1 which is symmetric to 1/x (rational and irrational number systems) and has infinitely many digits at the left side of the floating point?
In what sense is the second post "clearer"?
10K
  • · Replies 29 ·
