Solving Real Number Equations and Counting Integral Solutions: Help Needed!
  • Thread starter Thread starter mercury
The discussion revolves around two mathematical problems involving real number equations and counting integral solutions. The first problem concerns the existence of a real number \( c \) within a specified interval that satisfies a quadratic equation involving \( a \) and \( b \). The second problem asks for the number of non-negative integral solutions to a linear equation in three variables.
  • Mixed
  • Participants explore specific values for \( a \) and \( b \) to test the conditions of the first problem, questioning the generality of their findings. There are discussions about the implications of the intermediate value theorem and the conditions under which solutions exist. For the second problem, participants analyze the relationship between the variables and attempt to derive a formula for counting solutions based on the values of \( x \).
Multiple interpretations of the first problem are being explored, with some participants suggesting different answers based on their reasoning. The second problem has seen some consensus around the answer being 121, although the methods of arriving at this conclusion vary among participants.
Participants express uncertainty regarding the validity of their approaches and the assumptions made in both problems. There is an acknowledgment of the need for careful consideration of the conditions set by the problems.
mercury
the following two questions are in math..and i have no clue how to even start..
i got them in a test..
i would appreciate it if u could tell me what i should do , or what concept is involved...
1) if a,b,c belong to the set of all real no.s and a!=b(not equal to)
then
a)a^2+b^2+ab=3c^2 for some c in (a,b)
b)a^2+b^2+ab=3c^2 for not even one c in (a,b)
c)a^2+b^2-ab=3c^2 for some c in (a,b)
2)the no. of non-negative integral solutions for the eqn.
2x+y+z=20 are
a)132
b)121
c)144
d)none of the above
thanks in advance
1) Take a=0,b=1
a^2+b^2+ab=1;3*c^2=1 => c is in (a,b);
Correct answer : a)
2) x can be 0,1,2,3,...10
y+z can be 20,18,16,...4,2,0;
y can take 21,19,17,...5,3,1 values for every y+z;
So 21+19+17+...+3+1=121...
Correct answer : b)
You have to be a little more careful, Bogdan. Showing that there exists such a c for a=0 b= 1 doesn't show that there is such a c for any a,b.
(a+b)2= a2+ 2ab+ b2 so
a2+ b2+ ab= (a+b)2- ab
If (a+b)2> ab (a=1, b=0 for example then the right side is positive and there exist c such that 3c2 is equal to it.
If (a+b)2< ab (example, a= 1, b= -1) then the right hand side is negative and there is no such c (3c2 can't be negative).
The correct answer is b.
Correct answer : b)
Sorry but ... how did u reach this conclusion ?
I haven't reached any answer yet, but i have an approach.
x => 0
y => 0
z => 0
Let's first look at z.
Rearrange the original equation.
2x+y+z=20
z=20-2x-y
Therefore as x and y get smaller, z will get bigger.
So a the lower bound of x and y, you will have the upper bound of z.
The lower bound of x is 0, the lower bound of y is 0 too.
So the upper bound of z is 20-(2*0)-(0) = 20
So now we have a smaller range of z.
0 <= z <= 20
Do the same for x and y, you will reah the following conclusions.
0 <= x <= 10
0 <= y <= 20
And ... i am still thinking of remaining (here is a clue, for each value of x, a certain value of y+z will be determined, just find the number of posibilities for y+z on each value of x (of course not by trial and error :wink: )).
I will work on it and reply ASAP.
121
i get 121 for the last question.
Maybe I'm wrong...
But b) can't be (busta rhymes...) the correct answer...
I demonstrated that for a=0, b=1,c=sqrt(1/3)...so there is a c in (a,b)...there is an example...mine...
I think the problem is if the answer is a or c...because a=0 b=1 makes a and c correct...take a=2,b=3...and you'll probably find out that a is the correct answer...
Correct me if I'm wrong...
mercury, do you have the correct answers ?
I was finally able to continue my method (which i started in the last post) to find the answer of the question (of the second question).
The answer is 121.
Let me show you how ...
From the last post, i showed that
0 <= x <= 10
now suppose you wanted to solve the question by trial (try each value of x, and find the possible values of y and z at each value of x), you will get something like this.
(please note that if you are given a value for x, and a value of y, there will be only a single value for z that satisfies the equation, therefore it is not needed to list the values of z)
> x=10 (y+z=0)
>> only one posibility, which is that y = 0
> x=9 (y+z=2)
>> posibility one : y=0
>> posibility two : y=1
>> posibility three : y=2
> x=8 (y+z=4)
>> posibility four : y=3
>> posibility five : y=4
... so on ...
so far you have the following answers
(x,y,z)
(10,0,0)
(9,0,2)
(9,1,1)
(9,2,0)
(8,0,4)
(8,1,3)
(8,2,2)
(8,3,1)
(8,4,0)
... so on ...
Now you may see that the number of possibilities of y and z for each value of x can be expressed as
P=21-2x
(this is very logical **)
So the number of answers is
[sum](from x=0 to x=10)(21-2x)
=21*(10+1)[sum](from x=0 to x=10)(-2x)
=21*11 -2 * [sum](from x=0 to x=10) (x)
=21*11 -2*(10+1)*(10/2)
=231-2*(11)*(5)
=231-110
=121
Any comments ?
If (a+b)2 < ab (example, a= 1, b= -1)
Slight problem with this statement... the left hand side of this inequality is 0 while the right hand side is negative. It doesn't hold!
a) is correct for problem 1:
(without loss of generality, let a < b)
case 1: 0 <= a < b
notice that 3a^2 < a^2 + b^2 + ab < 3b^2, because:
a^2 = a^2 < b^2
a^2 < b^2 = b^2
a^2 < ab < b^2
Since 3c^2 is a continuous function, the intermediate value theorem says that there is a c such that:
3c^2 = a^2 + b^2 + ab
case 2: a < b <= 0
This time, 3b^2 < a^2 + b^2 + ab < 3a^2, and the same argument holds.
case 3: a < 0 < b
3a: |a| < |b|
3*0^2 < a^2 + b^2 + ab < 3b^2
Therefore there is a c in (0, b) for which equality is satisfied, and thus c is in (a, b)
3b: |b| < |a|
3*0^2 < a^2 + b^2 + ab < 3a^2
Therefore there is a c in (a, 0), and thus c is in (a, b)
3c: |a| = |b|
a^2 + b^2 + ab = b^2 + b^2 - b^2 = b^2
Setting c = b / sqrt(3) yields equality, and c is in (a, b)
Hurkyl
Thank you Hurkyl for the time spent proving rigorously the first problem...as I said...it was a)
hey people...thanks loads for answering my question and taking a lot of pains to explain it in detail...i have learned a lot of new things..
i suppose that's what this forum is for ...?
anyway i appreciate it..
cheers and peace
mercury
  • · Replies 71 ·
