Question involving beats and finding an unknown frequency.
  • Thread starter Thread starter insertnamehere
    Frequency
The discussion revolves around a problem involving beats and the determination of an unknown frequency using a standard tuning fork. The original poster presents a scenario where a known frequency of 262 Hz is compared to an unknown frequency, with beats heard at a frequency of 4 Hz.
  • Exploratory, Assumption checking
  • Participants explore the concept of beat frequency and its relationship to the unknown frequency. There is a discussion about the implications of altering the frequency of the standard tuning fork and how that affects the beat frequency heard.
Participants are actively engaging with the problem, offering hints and exploring the implications of changing the frequency of the standard tuning fork. There is a focus on understanding how the beat frequency can indicate whether the unknown frequency is higher or lower than the known frequency.
There is an emphasis on the need for further experimentation to clarify the relationship between the frequencies, and participants are questioning the assumptions about the unknown frequency based on the observed beat frequency changes.
insertnamehere
Hello.
I think I have the answer to the following question, but I'm not sure if I got the concept.
You have a standard tuning fork whose frequency is 262 Hz and a second tuning fork with an unknown frequency. When you tap both of them on the heel of one of your sneakers, you hear beats with a frequency of 4 per second. Thoughtfully chewing you gum, your gum, you wonder whether the unknown frequency is 258Hz or 266Hz. How can you decide?
Of course, the beat frequency is the absolute value of the difference between the two frequencies, but in order to decide whether the unknown would be four more or four less than the standard, I get lost here. A hint would be really appreciated. Help!
-thank you very much for your time.
HINT: Attach a small piece of your chewing gum to one of the tuning forks thereby lowering its natural frequency. Then repeat the experiment. What can you infer?
So, by lowering that tuning fork's natural frequency and repeating the experiment, I will have to see which tuning fork will continue to give me the beat frequency of 4 beats/second? I'm not sure if I got the concept right...
Suppose you lower the frequency of the standard (262 Hz). The beat frequency you would then hear will either be greater than 4 beats per second or less than 4 beats per second - i.e. it would either increase or decrease the frequency separation. What would you infer in either of these cases?
ok, so does that mean that it doesn't matter which frequency the unknown tuning fork was?
No. It is a means by which you can determine whether the unknown frequency of the second tuning fork is greater than or less than that of the standard tuning fork.
Ask yourself:
(a) If the beat frequency increases what does that tell you about the unknown frequency?
(b) If the beat frequency decreases what does that tell you about the unknown frequency?
  • · Replies 43 ·
