To make things easier to describe, let's imagine the empty corner is at the origin and the opposite diagonal (where q2 is) is somewhere on the y-axis. Thus q1 (on the left side of the y-axis) and q3 (on the right side) have the same y-coordinate, but opposite x-coordinates. Got it?
Originally Posted by smunger81
If both charges on opposite sides of the diagonal were positive you would have one charge pointing in the -x, -y direction and one pointing in the +x, +y direction.
Careful. Using my coordinate system the field from q1 will have components along the +x and -y directions; the field from q3 will have components along the -x and -y directions. So if q1 and q3 are both positive and equal, then the x-components would cancel, but not the y-components--those will
add.
So those two would cancel each other out.
See my comment above. The net field from q1 and q3 will point in the -y direction.
The other charge (on the diagonal) is a length = sq.root(a^2+b^2) away from the empty corner, according to pythagorean's theorem. But since it is a square, all of the sides are equal length of d so a and b would be equal. Thus the above distance equation would = sq.root(d^4). So how would a negative charge at this corner allow the empty corner to have an electric field of 0?
If the sides are length d, the diagonal is length
. Since the field from q1 and q3 points down (-y direction), to cancel that field you need to add a field pointing up (+y direction). A negative q2 will do that, but it needs to be the right size charge to cancel the other fields exactly.
