On number one, the angle is 10 degrees below the horizontal. That means your vertical component is negative.
On the other two, try drawing the problem out on paper. You're mixing up your components.
For example, the second problem is 21 degrees north of east. You solved for 21 degrees east of north.
In other words, you probably have the trig part down, but you need to work on defining the problem you're trying to solve.
