Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Partial Derivatives (Uncertainty) Share It Thread Tools Search this Thread image
Old Oct4-05, 01:05 AM                  #1
niteshadw
niteshadw is Offline:
I'm trying to find the uncerainty for the following equation:
e = Qd/AV, where Q is the charge in C, d is the distance in m, A is the area (Pi * r^2), and V is the voltage.
I get something like
delta_e = delta_Q/Q + delta_d/d + delta_A/A + delta_V/V but when I do that, I get a rather large uncertainty number that does not make sense so I think I got hte equation incorrectly....
The lab is based on capacitance and dielectrics...and e in his case is the permittivity of air, lexan, etc..that need to be calculated...
Old Oct4-05, 01:17 AM                  #2
CarlB
CarlB's Avatar
CarlB is Offline:
Recognitions:
Homework Helper Homework Helper
I've not seen this sort of problem assignment before, but I would try looking at uncertainty, at least for small uncertainties, as a differential.
The uncertainty in U = AB/C would be:
dU = (B/C)dA + (A/C)dB - (AB/C^2)dC.
Note that each of these is a signed error amount, so if you want the total (absolute) uncertainty, then you need to instead use:
|dU| = |B/C|dA + |A/C|dB| + |AB/C^2|dC
To verify these relations, you can try using small values for the errors and substituting. In fact, if your errors are large, you will get a more accurate value by direct substitution rather than using the approximate calculus equations given above.
Carl
Old Oct4-05, 05:04 AM                  #3
big man
big man is Offline:
Yeah do it the way Carl said, because the way you're doing it is going to significantly overestimate the associated uncertainty. However, I can see why you got such a high value because the formula you are using is:
e'/e = Q'/Q + d'/d + A'/A + C'/C
Where the ' signifies the uncertainty delta. So what you would need to do is multiply your initial result be "e" to obtain the uncertainty value.
But instead of using that method use the method outlined by Carl.
image image
Reply
Thread Tools
Similar Threads for: Partial Derivatives (Uncertainty)
Thread Thread Starter Forum Replies Last Post
Second partial derivatives fk378 Calculus & Beyond 9 Apr26-08 06:31 PM
Partial Derivatives? Saladsamurai Calculus & Beyond 17 Mar4-08 11:43 PM
Help with PDE (first partial derivatives) tpm Calculus & Beyond 0 May26-07 05:46 AM
partial derivatives UrbanXrisis Calculus & Beyond 3 Feb18-06 09:26 PM
partial derivatives, why is the fy this? mr_coffee Calculus & Beyond 2 Oct14-05 06:28 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
