Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Difference in Planet Mass Share It Thread Tools Search this Thread image
Old Oct4-05, 08:55 AM                  #1
Serena_Greene
Serena_Greene is Offline:
I think I have done this problem correctly,
The mass of a robot is 6680 kg. This robot weighs 3070 N more on planet A than it does on planet B. Both planets have the same radius of 4.00 x 10^8. What is the difference Ma - Mb in the masses of these plantes?
I used this equation F = G * (m1*m2)/(r^2)
F = 3070 N
m1 = robot
mb = extra mass of planet A
r = 4.00 x 10^8
3070 = 9.673 x 10^-11 * 6680m2/ (4.00 x 10^8)^2
3070 = (2.786 x 10^-24)m
1.1019 x 10^27 = m
Is this correct or do I have it totally wrong?
-Serena
Old Oct4-05, 09:07 AM       Last edited by Päällikkö; Oct4-05 at 09:43 AM..            #2
Päällikkö
Päällikkö is Offline:
Recognitions:
Homework Helper Homework Helper
I got a different answer, you seem to have typed it wrong into your calculator, the equation's the same as mine.
EDIT: Never mind. I had used the gravitational constant you typed, which was wrong :). I got the same answer now.
Old Oct4-05, 09:36 AM                  #3
El Hombre Invisible
El Hombre Invisible is Offline:
I tried it, though not using your technique, and your answer seems correct. Same answer from two different methods is usually a good sign.
Old Oct4-05, 09:37 AM                  #4
El Hombre Invisible
Although your answer should be in kg, not m.
Old Oct4-05, 06:07 PM                  #5
Serena_Greene
Thanks!!
I just wanted to make sure before I typed it into GradePlus. It was correct (I had already used up a try as I couldn't get the entire number in, but found out I could use Exponents) I asked my Physic teacher if I did the problem correctly and he started to do the problem, and he couldn't do the problem.
-Serena
image image
Reply
Thread Tools
Similar Threads for: Difference in Planet Mass
Thread Thread Starter Forum Replies Last Post
Mass of planet, given only Earth's mass? paperclip Introductory Physics 4 Apr19-07 03:33 AM
satellite question. find mass of planet and weight on planet? physics1007 Introductory Physics 2 Nov18-06 08:38 PM
A planet with mass m, and radius r..... J_o_S Introductory Physics 6 Jun7-05 08:05 AM
using kepler's laws to find mass of planet jhson114 Introductory Physics 8 May22-05 04:27 PM
mass of a planet??? Kacper General Astronomy 22 Jan21-04 10:36 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
