Air Pressure Between Highway Vehicles: Causes & Effects
  • Context: High School
  • Thread starter Thread starter NanakiXIII
    Air
The discussion focuses on the air pressure dynamics between highway vehicles, particularly when one vehicle overtakes another. Participants explore the causes and effects of air pressure changes, airflow patterns, and related phenomena, drawing on both conceptual and experimental perspectives.
  • One participant observes that when a bus overtakes trucks, a cloth covering the trucks is sucked outward, suggesting a decrease in air pressure between the vehicles.
  • Another participant explains that as vehicles travel parallel, they push air out of the way, leading to turbulence and a drop in pressure between them due to the upward momentum of the air.
  • Questions arise about how the pressure decrease influences air movement, with one participant noting that the air would naturally want to flow into the low-pressure area.
  • Participants discuss the upward momentum of air and how it relates to pressure gradients, comparing the situation to airflow over an aircraft wing.
  • There is a suggestion that the air carried along with the vehicles contributes to maintaining pressure dynamics, with friction transferring momentum from the vehicles to the air.
  • One participant describes the experience of driving behind trucks, noting a "flapping" wind effect due to differential flow rates and vacuum effects created by airflow patterns.
  • Another participant introduces the Venturi effect, drawing parallels to similar phenomena observed in parallel-moving ships and discussing pressure changes in relation to speed and distance.
Participants express various viewpoints on the mechanics of airflow and pressure dynamics, with no clear consensus reached. Some agree on the presence of a pressure drop and the role of airflow, while others introduce competing explanations and effects, such as the Venturi effect.
Participants mention the need for computational fluid dynamics models or experiments to visualize airflow, indicating that the discussion may be limited by the complexity of the phenomena and the assumptions made about airflow behavior.
This discussion may be of interest to those studying fluid dynamics, automotive engineering, or anyone curious about the effects of vehicle interactions on air pressure and airflow patterns.
NanakiXIII
Okay, sorry for that useless title, but I couldn't think up how to have it reflect my question in short.
I went on a trip to Rome and got there by bus. Along the way, the bus passed a lot of trucks and some of them had some sort of cloth covering their sides (I'm sure you know what I mean). It was normally just pressed against the trucks, more or less. However, when the bus moved into overtake the trucks, this 'cloth' was sucked outwards. I'm assuming that somehow the air pressure between the vehicles decreases. I was wondering what causes this.
When two vehicles are traveling parallel, both are pushing air out of the way. The air flows to side, over the top, or somewhat underneath, but it flows into the path of least resistance. The air then recombines behind the vehicles, and that is where a lot of turbulence will be seen.
Think about the momentum imparted to the air by each vehicle. The sideways momentum toward the inside of each vehicle cancels more or less, and what is left is the upward or downward flow.
Since the airflow is diverted up (mostly), the pressure between the vehicles drops. Toward the tops of the vehicles though the pressure is more or less equal or try to equalize.
But if the pressure between the vehicles decreases, isn't that exactly where the air would want to go?
The pressurized air in front of the vehicles gets an upward momentum which carries it up over the vehicles, then it has to flow under a pressure gradient back to the low pressure regions mostly behind the vehicle and somewhat toward the volume between the vehicles. This is a similar effect to the air flow over a wing of an aircraft.
You will feel a similar affect if you stand on a platform very close to the edge when a high speed train passes by, or if you stand on the edge of the traffice lane when a fast truck or bus passes by.
If you have a smoke generator you can see the effects.
Okay, I asked the wrong question. How do the flows to the inside cancel each other out?
If one looks at one vehicle traveling alone, one would see the air move sideways, roughly equal in either direction, as well as up over the top. Trucks and buses are generally more square or flat, i.e. the front is essentially vertical with repect to the air.
Anyway, when two vehicles are side-by-side, the air that would normally move to the side where the other vechicle is now located now encounters the compressed air from the other vehicle. The side flow momentum from one vehicle opposes the other. However, both flows have upward momentum, so the flow moves up.
The gap between the two vehicles also offers more flow resistance partly from the resistance from the sides of the vehicles, but also because that air is carried along with the vehicles now. The latter is probably the more important factor. The air between the vehicles is now pulled along to it has forward momentum with respect to the still air before the vehicles.
One also has the much low pressure behind the vehicles which also draws the air from between the vehicles.
The air pushed out of the way by the vehicles certainly tries to flow back between the vehicles, but not quickly enough - and the vehicles have passed before the air can move back between them.
Ah so mainly the flows just bounce each other up, keeping each other from going inbetween the vehicles.
And the air that is carried along with the vehicles (how does that happen, by the way?) also bounces back the flows? More or less making the two vehicles one whole for the air they pass through?
Yes, that is essentially the case.
The air will flow to the point of least resistance. Certainly some air leaks between the vehicles. One would a computational fluid dynamics model to demonstrate, or do an experiment with smoke generators (flow visualization).
Remember, for the most part, the air is relatively still (unless there is some breeze) and the vehicles are moving. The air is 'displaced' as the vehicle moves through it.
The air between the vehicles is carried along with the vehicles because the air is in contact with the surface of the vehicles. Friction transfers some momentum from the vehicle to the air. The gap between to adjacent vehicles is long (~10-15 m), high (~4-5 m) and relatively narrow (~1-2 m).
I get it, thanks.
To and fro
Excuse me but as someone who has driven a vehicule, truck, car, and motorcycle, the airflows around heavy trucks generates a Flapping (reciprocating) wind behind the truck due to the differential of Flows rates on either side of the truck, added to that is the simple notion that the Airflow passing towards the rear on the side of the truck creates a slight vacuum effect, as evidenced to anyone when they are the first to open a Window in a Car, the initial airflow there is from the inside of the car, to the outside, as the vacuum pressure abates slightly first. The reason why the 'sidedrapes' pillow, is due to that vacuum effect in a very temporary situation wherein the Air pressures between the two trucks lowers slightly while they pass, by restiction of airflow, usually when the two are proximal enough in their passing to have that immediate an effect upon each others airflows, also a very brief effect.
Most certainly I have driven a Motorcycle behind Large trucks and have experienced the somewhat violant, or vigorous 'tossing to and fro' attempt that the alternating side-Winds Blasts at you.
Open the window of just about any car, at speed, slightly, and it will give you a suction effect, not a positive Pressure effect.
Am I mucking things up?
LD
Stretches, **YAAAAAAAAWNS** thinks maybe he should go back to his Sumpteous Warren, to sleep, again.. .. ..soon.. .. ..←{Know what those are?}[/color]
Open the window on just about any fast moving vehicule and you will immediately have a Venturi effect as the outside air is rushing past at a much greater speed, then the inside air.
what will happen to the flow behind the bus or trunk?
There's an awful lot of words here that don't seem to make a lot of sense, for what is really a straightforward issue: between two vehicles moving in parallel, a venturi effect is created: http://en.wikipedia.org/wiki/Venturi_effect
The same thing happens to two ships sailing in parallel with each other. For navy ships doing underway replenishment 100 yards apart, it occasionally causes collisions.
5. Be aware of the Venturi effect.
a. When underway, there are areas of decreased water pressure (suction) amidships and increased water pressure at the bow and stern as the result of the differences in velocity of the flow of water around the hull.
b. When ships are alongside each other underway, this Venturi effect is increased and becomes further complicated because of intermingling of the pressure areas.
c. The Venturi effect is increased as the ship's speed increases, as the distance between ships decreases, and as the depth of the water decreases.
d. Avoid pointing your bow in toward the supply ship at the point of overlap or your bow will be sucked in by the Venturi effect.
http://www.fas.org/man/dod-101/navy/docs/swos/stu2/STU12.html
[edit] oops...very old thread. Sorry I missed it 5 years ago!
What do you mean? What happens to it when/what?
Are you just asking about the wake that all moving objects make? They drag an area of low pressure behind them.
  • · Replies 30 ·
  • · Replies 169 ·
17K
  • · Replies 17 ·
10K
