Solving for R & XL Given Z & Phase Angle
The discussion revolves around solving for the resistance (R) and inductive reactance (XL) in a series circuit containing a resistor and an inductor, given the impedance (Z) and the phase angle between current and voltage. The scope includes mathematical reasoning and conceptual clarification related to AC circuit analysis.
  • One participant presents a problem involving a resistor and an inductor in series, with a known impedance and phase angle, seeking to find R and XL.
  • Another participant points out that a capacitor is not present in the circuit, thus it does not factor into the impedance expression.
  • A participant introduces the relationship between the phase angle and the reactance, stating that tan(φ) = XL/R can be used to express XL in terms of R or vice versa.
  • Participants discuss the utility of phasor diagrams in visualizing the relationships between voltage and current in the circuit.
  • There is a request for further explanation on how phasor diagrams can aid in solving such problems.
Participants generally agree on the approach to solving the problem using phasor diagrams and the relationship between phase angle and reactance. However, there is no consensus on the specific steps to take or the final values for R and XL, as the problem remains open-ended.
The discussion does not resolve the values of R and XL due to the lack of additional information such as frequency (f) or inductance (L). The reliance on phasor diagrams and the manipulation of impedance expressions are noted as helpful but not definitive solutions.
smunger81
Here's a tricky one...
A resistor is in series with an inductor, with the current (I) lagging behind the voltage (V) by 60degrees. I am given the impedance (Z) of the circuit, which is 350ohms. How the heck can I find the resistance (R) and the inductive reactance (XL) when I know only the impedance and the phase angle.
XL=2pifL
Z=sq.root(R^2+(XL-XC)^2
What equation would I use...since I don't know f, L, or C?
Thanks! :smile:
Well you don't have a capacitor in your circuit to start off with so you don't actually need to know it, nor does it appear in the impedance expression. It usually helps to construct phasor diagrams in this situation. If you construct a phasor diagram you can see that the phase angle [tex]\phi[/tex] between the current and voltage is related by the expression:
tan([tex]\phi[/tex]) = [tex]X_L/R[/tex]
From this you can express [tex]X_L[/tex] in terms of R or R in terms of [tex]X_L[/tex] and then solve the original impedance expression of:
[tex]Z^2[/tex] = [tex]R^2[/tex] +[tex]X_L^2[/tex]
I knew that about the capacitor...I was unaware you could manipulate the impedance expression like that but it makes sense since there is no capacitor! Thank you so much for your help...so much.
Yeah the only reason it is [tex]X_L-X_C[/tex] for the impedance in an RLC series circuit is because the voltage across the inductor leads the current by 90 degrees while the voltage across the capacitor lags the current by 90 degrees.
But phasors sometimes help to make these questions a lot easier.
Do you mean drawing a phasor diagram makes it easier? Could you explain that last statement a little more if you get time...thanks.
Sorry yeah, what I meant was that for problems like that one it's easier to see how to answer a question if you use phasors. I've attached what I mean.
  • · Replies 20 ·
  • · Replies 21 ·
