Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Speed of A Bullet Share It Thread Tools Search this Thread image
Old Oct4-05, 06:30 PM                  #1
quicknote
quicknote is Offline:
Speed of A Bullet
Derive a formula for the bullet speed v in terms of D, T, and a measured angle theta between the position of the hole in the first disk and that of the hole in the second. If required, use pi, not its numeric equivalent. Both of the holes lie at the same radial distance from the shaft. Theta measures the angular displacement between the two holes; for instance, Theta = 0 means that the holes are in a line and Theta=pi means that when one hole is up, the other is down. Assume that the bullet must travel through the set of disks within a single revolution.
The picture can be found here.
http://ca.geocities.com/canbball/MRB_rr_8_a.jpg
I know that v = (delta)D/(delta)T where D is distance and T is the period.
But I'm not sure how to find the ratio between the angle and the measure of a full revolution.
Any help would be much appreciated!
Old Oct4-05, 07:07 PM                  #2
Integral
PF Mentor
Integral's Avatar
Integral is Online:
your equation
LaTeX Code:  v = \\frac {\\Delta D} {\\Delta T}
Cannot be correct. Both D and T are constants of your problem, so do not change.
You need to start with
LaTeX Code:  v= \\frac D t
where t is the time required to travel the distance between the disks. You are given that it take T secs to do a complete rotation, what is that in terms of Pi?
your goal is to find an expression for t involving T and LaTeX Code:  \\Theta  .
image image
Reply
Thread Tools
Similar Threads for: Speed of A Bullet
Thread Thread Starter Forum Replies Last Post
[SOLVED] The speed of a bullet may be determined by allowing the bullet to pass throu XxBollWeevilx Introductory Physics 9 Feb12-08 06:38 PM
Max bullet speed Dirk Bruere at NeoPax General Physics 3 Jun25-06 05:00 AM
Max bullet speed Dirk Bruere at NeoPax General Physics 0 Jun21-06 05:01 AM
Speed of a Bullet tigerseye Introductory Physics 1 Nov7-04 07:03 PM
Bullet speed- Please Help! Crashdowngurl Introductory Physics 3 Feb4-04 12:17 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
